Which says: "VoIP and SIP ... accomplish the same goal of connecting calls via the Internet, they are not the same thing."
It defines SIP as: "Session Initiation Protocol (SIP) is a communications protocol that is widely used for managing multimedia communication sessions such as voice and video calls. SIP, therefore is one of the specific protocols that enable VoIP. ...So there really is no such thing as SIP vs. VoIP. SIP is an industry standard method of achieving VoIP."
Since nospam is more often wrong than he is right, I will concur with him on this one, in that T-Mobile only offers the free 200MB/month for "tablets" (whether Android or iOS), so, a "phone" won't be eligible.
So, in this case, nospam is correct (as he is in the case below).
I used to use the AT&T and T-Mobile pay-as-you-go plans, both non-gold and gold.
With AT&T, they used to suck out three or so bucks a month, so, it was really a 3/buck-a-month and then pay as you go plan. The pay as you go part was something like 30 cents a minute (as I recall), so that sucked too.
So I went to T-Mobile, who would just drop the entire amount if I let it lapse - so that sucked also. Of course, if you kept putting money in, then it worked fine, and when you got to $100, you became gold.
I think *now* they require a single payment of $100 (I think - but I'm not sure) whereas in the olden days, you just had to accumulate 100 dollars.
Even so, if you let it lapse, they'd *expire* the darn SIM cards, so I had to buy a new SIM card whenever I wanted to start it back up, even though there was nothing physically wrong with the old SIM card (I have a stack of them lying in a drawer somewhere).
Overall...
Using the pay-as-you-go (for me) was such a pain that I dropped altogether the pay-as-you-go stuff, in favor of a second phone number on my cellphone (e.g., sideline) for free.
Even Sideline will drop you if you don't use it - but there's no cost involved, and, in a way, it's a privacy measure such that you don't always have the same number.
The easiest way to achieve most of this is with Skype . Skype will provide a real number almost anywhere in the world and his callers will be charged their standard rates to call this number. Skype will then handle the incoming call so that it will show up on his cell phone as a normal Skype call. Skype out will let him call real numbers from his phone at greatly reduced prices compared to standard cell phone charges. Skype out can display his Skype number as his caller ID.
I'm not sure why he would want to "make calls from any other phone" using his Skype number but Skype won't let him do that. Of course he can use any Skype capable device to make calls. Alternatively Skype will supply a roaming number in many countries so that he can make calls at Skype prices from other phones without using the Skype application.
There are dozens of other VOIP providers that supply similar services. A few will supply a real telephone number at no charge. In all cases only the direct connection of two users using the same VOIP provider are free to both ends of the call.
Most VOIP providers use SIP but Skype uses its own protocol for connecting calls. This won't matter to your friend unless he wants to add specialised hardware or software to his VOIP set up.
I've done some more research and if he is going to use VOIP, I'm sure it would be Hangouts/GV which is free to call anyone in the USA, unlike SkypeOut/SkypeIn, which isn't free (I don't think).
Whatever telephony you can muster up for an internet-connected computer you can muster up equally well for an internet-connected SIM-less cellphone -- just another computer, after all :-) . HTH. Cheers, -- tlvp
Really? Your number never gets randomly included in the 0000-9999 sweeps the telemarketeers' predictive dialing software indulges in? You've got better luck than I have, Gunga Din :-) . Cheers, -- tlvp
You can't use a GSM phone without a SIM card to make non-emergency calls. You can use a device with WiFi connected to the web and an operating system and application that support VOIP to make and receive phone calls via WiFi. "SIM" and "GSM" are not involved in any way.
We can talk more about that, after you are finished with the pissing contest with nospam.
Probably not an issue for 99% of people, but be aware that outgoing GV calls silently drop after 180 minutes. I thought I'd use GV to dial into some all-day presentations but found that I had to re-initiate the call every 3 hours.
