I'm trying to help a friend use her HP/Compaq NC6000 that apparently comes with an Intel 2200BG card work with the Linksys WRT54GS router I installed (successfully).
The issue I'm having, is that it connects fine with no access control (default), but fails when configuring the Linksys to use WPA Personal.
Incidently, she finds the the Intel PROSet connection applet.
So...
How should I configure the Linksys and the laptop to speak WPA so as to keep non-authorized users out of her AP?
Should I look at an alternative application that works with her embedded wifi card?
How come there's no comp.*.wifi ng on Usenet (tried wifi, wi-fi, wireless, wlan, with not much chance)?
Hardware version number of the WRT54GS router? It's on the serial number tag. If it's a WRT54GS version 5 hardware, make absolutely sure it's the latest firmware (which still doesn't work quite right).
I just went through a similar exercise on a Netgear WPN824 wireless router. They just couldn't get WPA2-PSK to work with 3 different laptops all using Netgear products and drivers. It was 3 versions of firmware behind. An update solved the problem. It also solved a really crappy thruput problem with high latency (Direcway) connections.
Good. Can she find the version of Proset she's using? 10.1.1.3 is the current version. It's well worth the monsterous 80Mbyte download. Much better control over everything and in my opinion, probably the best wireless client around.
Use WPA-PSK TKIP and not WPA2-PSK AES. Linksys calls this WPA Personal and WPA2 Personal. WPA2 has better encryption and authentication, but I keep running into bugs and glitches. WPA-PSK seems "good enough". Do not bother with WEP as it's not particularly secure.
No. Proset works just fine with everything I've ever tried. However, the Proset 9.x stuff was a bit glitchy. There were no connection problems that I know about, but it did have the nasty habit of dropping in speed in the presence of interference, and never recovering.
If you must look of an alternative, there's a check box somewhere that mumbles "Let Windoze manage the wirless network". That activates Wireless Zero Config, which might work. I much prefer Proset to WZC and suggest you continue trying to make it work before resorting to WZC.
Dunno. Wi-Fi is a trademark of the Wi-Fi Alliance. I suppose such a group would only about their certification efforts. There are also many different types of wireless connectivity discussed besides Wi-Fi. The world is not all Wi-Fi (802.11a/b/g) based. However, the real reason is creating a new group under the comp.* newsgroups requires an ordeal process with discussions and votes. I was once involved in a reorganization of the SCO Unix newsgroups. It took about 2 years. Under the alt.*, you just newgroup it and convince your usenet news provider to add the group to its feed. Much easier and faster.
I'm using an Intel 2200BG w/ WRT54G v2 router. I currently use WPA2 Personal w/ TKIP+AES, without any issues. Check the Authentication Type in the router's admin area, and try AUTO as opposed to SHARED KEY.
Is anyone else getting a broken link there and a "no longer available for download" when picking Wireless and 2200BG, or is it just because I'm out the "the" country?
Works for me. I had to go through about 3 pages after the above URL, but it eventually started the download. I think the downloaded file is fully localized and should have all the regulatory areas. Maybe try one of the international Intel web piles? Nope. I just tried the UK site and the Proset downloads page ended up exactly the same. I'm in the Peoples Republic of Santa Cruz California. Is Homeland Security watching your downloads? Maybe they're causing the broken link?
