Hi there, Having huge problems gettin wireless to work! Using Windows XP SP2 with a Dell Inspiron 6400. Wireless Network: Intel(R) PRO/Wireless 3945ABG Router: Linksys WRK54g (V1.1) (have tried with netgear and belkin) ISP: Telewest 2Mb/Motorola modem
I try 2 ways:
1) with the set up disk that finishes by tellling me that all is OK. 2) Manually, setting the routers configuration via web browser. I set up the channel (1 or 6 or 11), secure wep, clone mac etc.....)and I get 1 of 3 things happening:
1) the network is just not detected (either by Intel console..or Windows management). Have tried with and without thre Zero config 2) It is detetected, it connects, signal excellent... click on to browse and the page remains blank. The IP shows as 169.......... 3) The IP is fine (192......) can go online, but within hours I crawl and eventually die!!!I have had wireless for quite a while now. It worked fine and then just stooped working one day. Re configured but thinks have been going from bad to worse.
1) whatever router I use, the problem occurs. 2) what evernetwork card i try (sitecome usb, dell usb, intel, linksys card), same problem 3) whatever laptop I try it on (an acer, a dell and a sony), same problemThat seems to leave me with Telewest... or is there something else I should try before switching to BT! Thanks AD
