ALERT: WPA isn't necessarily secure
SUMMARY:
WPA-PSK is vulnerable to offline attack.
TO AVOID THE PROBLEM:
USE A PASSPHRASE WITH MORE THAN 20 CHARACTERS. Examples: BAD: "vintage wine" GOOD: "floor hiking dirt ocean" (pick your own words, even longer is better) FOR HIGH SECURITY, USE MORE THAN 32 CHARACTERS.
BACKGROUND:
Weakness in Passphrase Choice in WPA Interface By Glenn Fleishman By Robert Moskowitz Senior Technical Director ICSA Labs, a division of TruSecure Corp
... The offline PSK dictionary attack ... Just about any 8-character string a user may select will be in the dictionary. As the standard states, passphrases longer than 20 characters are needed to start deterring attacks. This is considerably longer than most people will be willing to use.
This offline attack should be easier to execute than the WEP attacks. ... Using Random values for the PSK
The PSK MAY be a 256-bit (64 hexadecimal) random number. This is a large number for human entry; 20 character passphrases are considered too long for entry. Given the nature of the attack against the 4-Way Handshake, a PSK with only 128 bits of security is really sufficient, and in fact against current brute-strength attacks, 96 bits SHOULD be adequate. This is still larger than a large passphrase ... ... Summary ... Pre-Shared Keying is provided in the standard to simplify deployments in small, low risk, networks. The risk of using PSKs against internal attacks is almost as bad as WEP. The risk of using passphrase based PSKs against external attacks is greater than using WEP. Thus the only value PSK has is if only truly random keys are used, or for deploy testing of basic WPA or 802.11i functions. PSK should ONLY be used if this is fully understood by the deployers.
See also: Passphrase Flaw Exposed in WPA Wireless Security
Wi-Fi Protected Access. Security in pre-shared key mode
Cracking Wi-Fi Protected Access (WPA)
WPA Cracker
John Navas
Does this apply to WPA2 as well? Mine is 28... should I make it 32 or more? bj
John Navas wrote:
chicagofan
28 should be fine as long as you didn't use something easily guessed/cracked; e.g., "now is the time for all good".
On Mon, 20 Nov 2006 17:33:25 -0500, chicagofan wrote in :
John Navas
LOL... no, it's a combination of letters, characters and numbers... although sort of in a *pattern*, so I can easily recall. That kind of worried me. bj
chicagofan
On Tue, 21 Nov 2006 12:15:19 -0500, chicagofan wrote in :
Another way to go with a diceware word passphrase with an easily remembered acronym that helps you remember the passphrase.
John Navas
On Mon, 20 Nov 2006 17:33:25 -0500, chicagofan wrote: : Does this apply to WPA2 as well? Mine is 28... should I make it 32 or more? : bj
Good luck with that. If you're using the relatively new, and relatively expensive, Linksys WAP54GP, you're limited to 20. (Alas, that AP has other problems that are even more serious.)
Bob
Robert Coe
What problems are you experiencing?
decaturtxcowboy
