I have a Linksys WRT54G router that I plan to add to an existing network which is using a Cable Modem, Cisco router and a hub. It is a Novell network if that matters.
I've learned that to incorporate the wireless router into the network, I need to disable the DHCP on the Linksys router. Fine...that's easy enough.
I've also learned that I need to change the LAN IP address of the Linksys router to correspond with the Cisco router's IP address.
When I look at Network Connections on one of the connected PC's it shows the IP Address to be 10.10.10.10 and the subnet mask to be 255.255.255.0
I'm accustomed to seeing IP address look like 192.168.0.101 or something like that so I'm not sure what to make of the 10.10.10.10 address.
Am I on the right track here? If that is a valid IP address, then the next step is to enter that address into the LAN IP of the Linksys, use a straight through ethernet cable from an available port on the Cisco router to the Uplink port on the Linksys and all should then work?
Comments?
Thanks,
Michael
