- Vote on answer
- posted
18 years ago
Buy them both at the same time as wireless will not work with just one. That said, if you get the Laptop, it can be ethered in but no wireless.
My current setup is like the following:
D-Link DI-704 4-port DSL router is connected to 3 desktops with one port unused.
I want to buy a notebook with a WI-FI connectivity built in.
I would like to connect a wireless connect point (WAP)to the remaining DSL router port.
Before I buy a notebook, I would like to get all parts compatible with one another. Which one do I need to decide first, WAP or notebook?
I don't think it makes difference as to when you get them.
Duane :)
First, you decide what you want to do (as above). Then, you decide how much money you want to spend on this exercise. The dollar limit will determine what you can afford to buy. Make sure everything will do 802.11g.
Most new notebooks come bundled with wireless of some sort. Might as well take whatever the manufactory supplies at the client end.
Since you already have a suitable router, adding wireless can be done in 2 ways.
To convert a wireless router into an access point:
Good luck.
I've just done this: my existing network is a one-port DSL router and a four-port switch with a web server wired in.
802.11g is a standard, so components *should* work together. "Extensions" to the spec such as WPA-PSK (AES) encryption may not be supported by both units, but you should at least have 128-bit WEP (for what that's worth...) as a common denominator.I bought a Belkin WAP and plugged it into my switch; and bought an HP nx6110 laptop with Intel wireless. Works perfectly.
