Will connecting a grounding rod to a pc frame enhance wifi signal reception strength on a typical usb radio? If so, should you ground the radio body or the pc frame or both?
- posted
13 years ago
No.
2.4GHz is microwaves which does not require a grounded counterpoise for propagation. The length of the ground wire is also such that it becomes an rf choke (inductor), making it useless for RF grounding.Cabling-Design.com Forums website is not affiliated with any of the manufacturers or service providers discussed here. All logos and trade names are the property of their respective owners.
