I let WinXP-SP2 manage my connections. When I right click on the wireless icon in the Systray, I see options of "status", and "disable", if the wireless is connected.
If the wireless isn't connected at the moment, I don't see "disable".
I like to disable the wirless when I'm not using it, to conserve power on the laptop. In order to disable it, I need to open the network connections, select it, and disable it...
I'd like to see "disable" be available in the context menu, and, for that matter, get rid of the "repair", which is kind of hazardous in a static IP environment.
