About Network Stumbler
Hello I have a tinsy question, and to cut it short: What does Network Stumbler do?
I can see it detects networks, and that works fine but what can you do once you've found a particular network? Let's say if one were to try to gain access to one's own network in order to test security, because that's something which musn't go wrong in my job.
But I digress,
thanks in advanced
Samael
As you've seen it detects networks and allows you to make graphs of signal strength versus time. I use that feature for doing quick-n-dirty site surveys (nope, the signal pretty much goes away in your family room, we're going to need to move the AP or add another one in this end of the house.)
Can't help you with breaking into (even your own) networks, the subject has no interest for me. Turn on WPA with a non-dictionary key and spend your time on more useful pursuits.
William P.N. Smith
