a repeater
I need a solution.
A repeater to pick up a signal through a reverse SMA cable (from an external aerial - only way to get signal to where it needs to go) and then i want the repeater to repeat the signal within a 10-25 meter radius of its self.
Will this mean getting a device with 2 aerials? How can i do this?
I have been looking at this, good idea?
The signal will orignally be coming from a dlink wireless router di-624 - will this effect anything? Will it be compatible with all repeaters?
With thanks Stuart
Stuart Turrell
I am not aware of Wi-Fi boxes configured as wireless repeaters. You can make do with two W-Fi boxes: connect wireless access point to external antenna, from the access point to the bridge for local coverage.
Andrey
