First, I have a couple of old routers, and I'd like to use them as network switches to expand my wired network a bit. I have an old Linksys WRT54G and an almost as old Netgear WGR614. The wireless spectrum is crowded in my neighborhood, so if possible I'd like to disable the wireless capability of one or both of these. Is this possible, and if so, is it safe to do so? Is it easily done?
The reason for this is to enable wired access to the network in several different rooms by 2 or more devices in each room, without running new cable fron the main switch in my main computer room.
And if the wireless capability can't be disabled, once the router(s) are set up as access points, is there any good way to simply reduce the range of the wireless capability? The WRT54G has removable antenna... any harm from simply removing them?
And since I don't intend to use the wireless capability of them, is it even necessary to convert them to access points.... can I simply plug them in and use them as switches?
Any suggestions appreciated.
