Wireless Networking Zyxel - False Advertising! - Beware of this Company!
Subject Author Date
Zyxel - False Advertising! - Beware of this Company! Le Chaud Lapin 07-02-08
Posted by Le Chaud Lapin on July 5, 2008, 11:25 am
wrote:
> Le Chaud Lapin wrote:
> >> TLDR
> >> Quit whinging about it and move on.
> > No one asked your opinion.
> Out of interest, who asked yours?
> And FYI, this is usenet, nor your private chatroom. You post a comment,
> people reply, thats how it works. Not all the replies will agree with
> you or be ones you like. If you don't like the replies, grow a thicker
> skin.
I made the comment anticipating that someone, especially the person I
made it to, would respond as you and Robert Redelmeier did.
What is remarkable is what you both say is 100% true, which means we
could go back an forth indefinitely.
In essence, anything goes.
-Le Chaud Lapin-
Posted by Jeff Liebermann on July 5, 2008, 12:02 pm
On Sat, 5 Jul 2008 08:25:26 -0700 (PDT), Le Chaud Lapin
The easiest way to determine if you want to continue an endless
discussion is to ask yourself if you would be interested in reading
what you're about to post. If the answer is negative, then cease,
desist, and don't post. Following my own advice, some useful content:
There's been some litigation over "Vista Capable" and "Vista Ready"
claims for various products that really are not.
<http://blogs.computerworld.com/bought_a_vista_capable_junk_pc_you_may_be_in_luck>
Google should help you find other suits involving claims of false
compatibility. For example, Nvidia can't seem to get it right:
<http://hardware.slashdot.org/article.pl?sid=07/02/03/0110248>
<http://www.nvidiaclassaction.org>
If you're serious about having been grievously injured by your
purchase of a Zyxel AG-225H, then I suggest you initiate or join one
of the numerous class action suits. Otherwise, just return it to your
vendor or sell it on eBay.
In reality, everything goes.
Jeff Liebermann jeffl@cruzio.com
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Posted by Le Chaud Lapin on July 5, 2008, 12:44 pm
> what you're about to post. =A0If the answer is negative, then cease,
> desist, and don't post. =A0Following my own advice, some useful content:
> <http://blogs.computerworld.com/bought_a_vista_capable_junk_pc_you_may...=
> compatibility. =A0For example, Nvidia can't seem to get it right:
> <http://hardware.slashdot.org/article.pl?sid=3D07/02/03/0110248>
> of the numerous class action suits. =A0Otherwise, just return it to your
I guess one should not be suprised that a few companies are trying to
claim Vista-compatibility when they know that it is non-existent or
partially existent. No one wants to wasted development resources on an
OS that has been adopted with uncertainty.
In the case of Zyxel, it appears that the only truly Vista-compatible
software is the device driver itself and the Installshield shell that
does the installation, which, of course, they didn't write. The rest
of the software, if I am not mistaken, is XP-only. But since NDIS 5.1
drivers will often work without modification from XP to Vista x86, my
guess is that the driver was tested to see if it would work in station-
only mode on Vista, and if it did, then Zyxel resolved that they would
claim "Microsoft Vista Support Out Of The Box", knowing that no
software was written specifically for Vista, but hoping that anyone
hoping to use the the Access Point feature on Vista would not
complain.
In any case, as of 2008-06-02, the US Federal Trade Commision has
launched a formal investigation of Zyxel's Vista-support claims of the
AG-225H, so we'll see what happens.
Your links and comments much appreciated,
-Le Chaud Lapin-
Posted by Jeff Liebermann on July 5, 2008, 3:02 pm
On Sat, 5 Jul 2008 09:44:34 -0700 (PDT), Le Chaud Lapin
Ooops. That was a terrible example as the class action web pile is
now owned by a domain squatter and the class action suit was
apparently never initiated.
I know of one company, that paid an expert to test some of their
existing XP drivers for Vista compatibility. They didn't want to pay
Microsoft to certify the drivers. Apparently, he did a not so
wonderful job of testing, and pronounced that everything was just fine
with minimal tweaks. The company announced that most of their
products and drivers installed and functioned under Vista. It took
about a month for the complaints to accumulate in support, along with
a dramatic increase in returns, to convince marketing that perhaps
something was not quite right. I haven't bothered to check if
anything was actually done about it.
For entertainment value, MS labels "Vista Capable" and "Vista Premium
Ready" PC's.
<http://www.microsoft.com/windows/products/windowsvista/buyorupgrade/capable.mspx>
and various levels of Vista certification. You might wanna see if
your hardware is compatible, ready, certified, blessed, or compatible:
<http://winqual.microsoft.com/HCL/Default.aspx> (IE6 or IE7 only).
Looks like Zyxel has certified some wireless devices, but not the
AG-225H.
<http://winqual.microsoft.com/HCL/ProductList.aspx?m=v&g=d&cid=711&f=86p>
Note that some of the model numbers are missing from the certification
list. I wonder why.
Actually, that phrase is not one of the offical Microsoft labels and
could very well indicate that they did their own testing.
Incidentally, if you read the phrase exactly as you wrote it, it means
you can call Microsoft and get Vista support by opening the box. I
don't think that's what they intended, but that's what it says. Not a
very good OOBE (out of box experience).
Reference? URL? I couldn't find anything with Google.
Posted by Le Chaud Lapin on July 5, 2008, 4:25 pm
> Ready" PC's.
> <http://www.microsoft.com/windows/products/windowsvista/buyorupgrade/c...=
> and various levels of Vista certification. =A0You might wanna see if
> <http://winqual.microsoft.com/HCL/Default.aspx> =A0 (IE6 or IE7 only).
> AG-225H.
> <http://winqual.microsoft.com/HCL/ProductList.aspx?m=3Dv&g=3Dd&cid=3D711&=
f=3D86p>
> list. =A0I wonder why.
Oh I bet they did. Remember here, though, I am not talking about the
driver. It was the user-mode software that does not work on Vista,
and the user-mode software drives the driver, which means that, if
all I have are Vista machines, I cannot use the dongle as an AP.
> you can call Microsoft and get Vista support by opening the box. =A0I
> don't think that's what they intended, but that's what it says. =A0Not a
> Reference? =A0URL? =A0I couldn't find anything with Google.
The investigation just started (at my behest), meaning any consumer
can cause and investigation of any company for any reasonable claim of
false advertising.
I will however, say that the FTC representative was suprisingly
diligent in verifiying details, etc. I also discerned from our
conversation Zyxel is not the only company playing this game.
-Le Chaud Lapin-
Similar ThreadsPosted
Zyxel - False Advertising! - Beware of this Company! July 2, 2008, 1:20 am
Microsoft blatant false advertising of MN-710 March 25, 2005, 2:54 am
beware of OxfordTEC UK December 27, 2007, 5:08 am
Zyxel 660HW June 26, 2005, 4:38 am
Need scan of Zyxel UPC February 12, 2006, 6:15 pm
any hack kow how to get zyxel b-220 usb 802.11 nic going? January 14, 2007, 4:20 pm
Need WEP key--Not on Zyxel "web configurator"--please help June 19, 2008, 2:43 pm
Beware all you DLink users! October 30, 2004, 5:28 am
Zyxel 660HW-61 PE.10 firmware December 11, 2005, 12:48 pm
Which Voip company do you think is best? January 2, 2008, 6:54 pm
Moving Company January 24, 2008, 11:40 pm
Zyxel 660HW drops connection October 31, 2005, 5:14 am
Zyxel G-470 vs Senao ? What's the best client bridge ? January 2, 2007, 9:05 pm
Zyxel 660HW-61 Internet over Wireless June 6, 2006, 4:07 am
Company network slowdown September 9, 2005, 11:29 pm
