Wireless Networking Wireless not working with certain sites
Subject Author Date
Wireless not working with certain sites Joao Saraiva 11-29-05
Posted by Joao Saraiva on November 29, 2005, 5:06 pm
Hello group
I wonder if some of the very knowledgeable members of the group can help me
with this.
1/ I am with F2S (freedom to surf) since March (2MBit)and everything was
working perfectly with my Speedtouch 716G wifi router
2/ In October I was upgraded free of charge to 8MBit and my problems started
3/ I cannot access sites like Hotmail.com / open MSN / fasthosts.co.uk /
nationalrail.co.uk while i manage to access others like cnn.com or ft.com
without any problem !
4/ However, if i disconect the wifi and i connect using the ethernet
everything works fine !!!
5/ F2S seems not able to help me to reconfigure (?) the speedtouch (which i
tested in another line and it works fine with ALL the above sites) ...
Any idea ? Does anyone understands why a site is accessible via ethernet and
not wifi ? ...
Thanks for your help
JS
Posted by Eugene F. on November 29, 2005, 12:23 pm
<<< Does anyone understands why a site is accessible via ethernet and
not wifi ? >>>
Run IPConfig (or its equivalent) and compare Subnet Mask values in both
cases.
Posted by Eric Parker on November 29, 2005, 10:44 pm
> Hello group
help me
> with this.
was
started
fasthosts.co.uk /
ft.com
(which i
ethernet and
> not wifi ? ...
MTU set differently ?
Eric
Remove the dross to contact me directly
Posted by Duane Arnold on November 30, 2005, 6:20 am
> / nationalrail.co.uk while i manage to access others like cnn.com or
> ft.com without any problem !
The only time I have seen this kind of problem was due with a problem in
the frimware of the router.
The usual fix for this was flash the router with the lastest version of
the firmware again but that was usually for someone who has a brand new
router that was having the access some but not other sites issue. You may
want to try that.
The other thing you might want to do is simply hard reset the router
setting back to factory defaults and turning it off for a little bit.
Then you can reconfig the router.
You can try either one and see what happens.
Duane :)
Posted by Joao Saraiva on November 30, 2005, 10:02 am
Many thanks to all of you that tried to help me !
I tried the different solutions, but end of the day the update of the
firmware available from speedtouch managed to solve the problem !
Thanks again.
JS
> Hello group
me
> with this.
started
i
and
> not wifi ? ...
> JS
Similar ThreadsPosted
Wireless not working with certain sites November 29, 2005, 5:06 pm
Wireless network slow on some sites February 1, 2008, 5:16 am
Laptop will not find Google sites when wireless December 7, 2006, 1:43 am
Laptop will not find Google sites when wireless December 7, 2006, 2:27 am
how secure are https sites over wireless at a public library ? June 4, 2006, 5:42 am
blocked sites June 10, 2005, 5:25 am
why not have https for all sites August 31, 2006, 11:01 am
Very Important Web Sites on the .Net November 26, 2007, 3:35 am
Directory of Wap/Mobile Sites December 9, 2007, 10:56 pm
Proxy sites list. April 11, 2008, 1:21 am
Centralised Wirelss Across several sites? July 2, 2008, 12:51 pm
Best Way for 2 Sites 200 feet line-of-sight?? October 20, 2005, 12:43 am
74302 Great Sites for Computer and Internet Lovers January 19, 2007, 8:40 am
84356 Great Sites for Computer and Internet Lovers January 19, 2007, 8:57 am
12178 Great Sites for Computer and Internet Lovers March 29, 2007, 3:47 pm
