Wireless Networking Wireless not working
Subject Author Date
Wireless not working Neil 02-03-06
Posted by Bob II on February 7, 2006, 8:38 am
Neil wrote:
> Bob
> I've been trying lots of different combinations according to which AP I'm
> trying to connect through at the time. Tonight I've been trying to connect
> via an SMC wireless AP and an ETEC router/modem. The main area I've looked
> at is TCP/IP properties for the wireless card in the laptop.
> In the general tab, I've left things as "Obtain an IP address
> automatically" - this works on the old laptop but not the new one. So, I've
> entered details on the "Alternate Configuration" tab. I've given a static IP
> address (192.168.0.32), subnet mask 255.255.255.0 and I've entered the
> gateway IP addy of my router (10.0.0.2).
Which unit provides your DHCP addresses?If it is router(10.0.0.2) then
check it's DHCP allocation as 192.158.0.32 is not on the same subnet and
will not work.What happens if you use 10.0.0.200 as your Static IP in
the "Alternative Config"?
The DHCP on your wireless card should have connected before trying the
Static IP, I have just tried this several times and on each occasion the
DHCP has connected and not used the Static IP.The Static IP only worked
when I disabled DHCP on the router.
I've also entered 217.32.105.90 qnd
> 91 for DNS servers. This apparently lets me connect with an excellent
> connection but I still can't access anything n the Internet.
> As far as I can see, all settings on the new lappie are the same as on the
> old lappie. I'm sure that I've got WEP keys and MAC filters set up
> correctly.
What happens without encryption and mac filtering, new wireless new MAC
address to include in your WAP Filters.
My gut feeling is that it's down to something to do with a newer
> wifi card on the new lappie but I don't know what.
> I'm getting very fed up with this. I've done lots of this type of connection
> in the past and never had problems like this.
> Neil
Posted by Neil on February 16, 2006, 9:40 am
> Neil wrote:
>> Bob
>> connect
>> looked
>> I've
>> IP
> will not work.What happens if you use 10.0.0.200 as your Static IP in the
The access point seems to be providing the DHCP addresses. However, if I
disable DHCP in the access point, it is allocated via the router. However, I
still can not connect to the Internet.
>> the
>> correctly.
I've disabled mac filtering and encryption for the time being to check that
this isn't causing my problems. It hasn't helped.
I've also tried disabling the on-board wifi card and plugged in an older
802.11b pcmcia wireless card. I felt sure I'd be able to connect with this,
but haven't been able to. I'm not sure what this signifies though except
that it's not just a problem caused by the 802.11g on-board wireless.
I've also downloaded the latest drivers for the on-board wi-fi card. No
difference.
>> connection
>> Neil
Similar ThreadsPosted
wireless isn't working!! January 31, 2006, 11:20 am
Wireless not working February 3, 2006, 5:12 am
g3 wireless ics not working November 14, 2006, 4:13 pm
Wireless working on one PC but not on another November 11, 2007, 4:35 pm
Wireless not working November 19, 2007, 6:25 am
Help! XP wireless not working May 4, 2008, 3:43 pm
Wireless not working with certain sites November 29, 2005, 5:06 pm
Wireless adapter not working December 28, 2006, 12:17 pm
Wireless network not working January 27, 2007, 1:42 pm
Wireless connection not working March 28, 2007, 10:52 am
Help! wireless link between computers not working April 3, 2005, 10:38 pm
wireless connection working intermittently August 2, 2005, 9:32 pm
Wireless router stopped working February 11, 2006, 12:25 pm
Tp-Link Wireless Router not working August 3, 2006, 11:29 am
Wireless Internet Stopped Working January 22, 2007, 1:59 am
