Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by kimiraikkonen on February 13, 2007, 5:45 pm
Please log in for more thread options My Acer Aspire 3000's built-in Broadcom BCM4318 adapter stopped suddenly working. I have tried re-installing drivers and used Broadcom's utility with no luck. It is not IP or firewall configuration related i promise. The main problem, although wi-fi adapter seems to working in ''network connections'' and ''device manager'' , the WI-FI LED of notebook is no longer lits up! Before this problem it was litting up normally and after XP Home SP2 opens, the lits become steady as it is connected. Now, there is no Wi-fi light litting onto my notebook? Hardware failure? Thank you very much... | |||||||||||||
Posted by kimiraikkonen on February 13, 2007, 6:28 pm
Please log in for more thread options wrote: Update, i got it working by pressing down wi-fi button as it turns wi- fi functioning.. What a secret button located by Acer! | |||||||||||||
Posted by Curly Bill on February 14, 2007, 12:00 am
>> Now, there is no Wi-fi light litting onto my notebook? >> >> Hardware failure? >> >> Thank you very much... >
> Update, i got it working by pressing down wi-fi button as it turns wi- > fi functioning.. What a secret button located by Acer! > Good, now you know where the switch is. You should note that when operating on battery power and not using WI-FI you should disable the wireless function to conserve battery power . | |||||||||||||
Posted by John Navas on February 14, 2007, 12:58 pm
>should disable the wireless function to conserve battery power The difference will be small for most good wireless hardware, which only use a small amount of power to listen for other wireless. It's transmit that burns most of the power, and that won't happen unless you actually make a wireless connection. -- Best regards, FAQ for Wireless Internet: <http://Wireless.wikia.com>
John Navas FAQ for Wi-Fi: <http://wireless.wikia.com/wiki/Wi-Fi> Wi-Fi How To: <http://wireless.wikia.com/wiki/Wi-Fi_HowTo> Fixes to Wi-Fi Problems: <http://wireless.wikia.com/wiki/Wi-Fi_Fixes> | |||||||||||||
Posted by John Navas on February 14, 2007, 12:56 pm
On 13 Feb 2007 14:45:25 -0800, "kimiraikkonen" >My Acer Aspire 3000's built-in Broadcom BCM4318 adapter stopped
>suddenly working. > >I have tried re-installing drivers and used Broadcom's utility with no >luck. It is not IP or firewall configuration related i promise. > >The main problem, although wi-fi adapter seems to working in ''network >connections'' and ''device manager'' , the WI-FI LED of notebook is no >longer lits up! > >Before this problem it was litting up normally and after XP Home SP2 >opens, the lits become steady as it is connected. > >Now, there is no Wi-fi light litting onto my notebook? > >Hardware failure? Did you accidentally turn it off? Many laptops have a hotkey combination or button to turn wireless on and off. -- Best regards, FAQ for Wireless Internet: <http://Wireless.wikia.com>
Wireless adapter stopped working! Please help :(
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> suddenly working.
> longer lits up!
> Hardware failure?
