Wireless Networking Wireless Internet Stopped Working
Subject Author Date
Wireless Internet Stopped Working arilisanne 01-22-07
Posted by arilisanne on January 22, 2007, 1:59 am
Please help me, tech gurus!! I have a SONY Vaio (PCG-TR1A) and a
Linksys Router - WRT55AG. The wireless on the laptop has never worked
all that well -- the connection used to cut out frequently, but
repairing it usually did the trick. Now, it will not connect at all.
I can see all the available wireless networks including mine. I hit
connect and it just says "Waiting for the network" until it tells me it
is unable to connect.
The connection is fine when connected directly with a wire.
A newer Gateway laptop in the house works perfectly wirelessly and has
no problems. Thus, it is not the router.
I have WEP security enabled, but I have tried disabling the security
and have the same problem, so that's not the problem.
I have tried disabling the Windows firewall.
I have tried disabling and then reenabling the wireless network; I have
reset the router.
Does anyone have any suggestions? I'm completely stumped.
The computer is running Win XP with SP2 installed.
Thanks.
Posted by on January 22, 2007, 3:31 am
The wireless connection issues through the router can be caused by not
deleting other networks under preferred network.
To delete other networks under preferred network, please follow these
steps:
1. Click on the Start menu and select the Run option.
2. After the "Run" window appears, type control ncpa.cpl into the
"Open" field, then click Ok.
3. When the "Network Connections" window opens, right click on the
Wireless Network Connection and go to Properties.
4. After the "Wireless Network Connection Properties" window opens,
click on the Wireless Networks tab.
5. When the "Wireless Networks" area opens, look for Preferred
Networks section.
6. Highlight the wireless networks and then click on Delete or Remove
option.
7. Restart the computer.
8. After deleting the preferred network; click Add and type in the name
of your wireless network.
9: If you are using WEP as an encryption; uncheck the key is provided
for me automatically and manually type in the network key.
10. Click Ok all the way out and connect to your network.
> reset the router.
> Thanks.
Posted by arilisanne on January 22, 2007, 5:34 pm
Annie - Thanks, I have tried this already- I have removed all other
networks, have removed all networks, actually, and added mine. It has
not helped. It can see my network and shows it as availble, but does
not let me connect to it. Any other suggestions? Thanks.
> steps:
> Networks section.
> option.
> > reset the router.
> > Thanks.- Hide quoted text -- Show quoted text -
Posted by seaweedsteve on January 22, 2007, 9:20 pm
I had a similar problem with a Belkin PCMCIA wireless adapter not long
ago. It suddenly would not connect, in the same manner as yours, no
address. Assigning an address would not work either. Had a good
signal. It failed on both laptops the same time.
I tried my other wireless adapter card on both laptops and they worked.
You might do the same. Try a USB or card and see.
I thought it was the linksys router, but then I happened to be changing
routers and the Buffalo was the same.
I uninstalled and reinstalled the card's drivers several times. No
luck.
Finally, I uninstalled the driver once more and then, while I was
online using a USB adapter (or ethernet) I let XP find the driver for
the card. No client manager, just the driver.
This worked. I still don't know what happened. I did install another
wifi card around that time, possibly this was it?
To sum up, look for ways to uninstall and reinstall your drivers,
different drivers, with and without the client manager included. Don't
need the client manager, XP will do it fine.
Steve
Posted by ejm on January 23, 2007, 12:52 am
Reinstalling driver is possible, but I would go to the linksys site and
see if there is any new versions of firmware for the router. That is
what solve my issue with my router.
Gene
> luck.
> Steve
Similar ThreadsPosted
Wireless Internet Stopped Working January 22, 2007, 1:59 am
Wireless router stopped working February 11, 2006, 12:25 pm
Wireless adapter stopped working! Please help :( February 13, 2007, 5:45 pm
My Sony Vaio wireless connection stopped working December 1, 2007, 1:02 pm
WRT54G Stopped Working November 26, 2004, 4:16 am
Dynamic IP stopped working [?] November 21, 2005, 1:24 pm
Laptop antenna stopped working May 1, 2007, 11:57 am
Linksys WAG54G Ethernet Ports Have Stopped Working July 14, 2006, 4:17 pm
Laptop suddenly stopped connecting to Internet March 20, 2007, 11:03 pm
wireless internet stops working at times June 14, 2007, 12:44 pm
Linksys WVC54G internet video camera wireless not working July 18, 2005, 10:49 am
internet not working on any comps December 21, 2007, 5:24 pm
Weirdest problem ever: Internet not working when my POWER CABLE is plugged in! May 7, 2008, 3:51 pm
WGR164v5 stopped doing wireless. August 3, 2008, 11:03 am
wireless network stopped allowing file sharing June 22, 2005, 11:26 pm
