Wireless Networking Will 802.11b Adapter Work with 802.11g Router?
Subject Author Date
Will 802.11b Adapter Work with 802.11g Router? phil6666 08-01-07
Posted by phil6666 on August 1, 2007, 6:59 pm
Long story short-
Had a Netgear Wireless Router MR814v2 (802.11b) hooked to a VISTA PC
and it worked fine with an XP PC using a Netgear MA101 (802.11b)
adapter.
Bought a new laptop with VISTA which wouldn't connect with the Netgear
Wireless Router MR814v2 since this router's not VISTA compatible.
Just got a Belkin F5D7230-4 (802.11g) router and the laptop works
fine.
Now my XP PC with a Netgear MA101 (802.11b) adapter recognizes the
Belkin router, but won't connect. (firewall is off)
Security set to NONE on router.
Is this a compatibility issue between a 802.11b adapter and a 802.11g
router?
Is this a compatibility issue between a Netgear adapter and a Belkin
router?
Am I just doing something wrong????
thnx
Posted by Jeff Liebermann on August 1, 2007, 7:28 pm
Nope. Vista is not router compatible. See:
"Windows Vista cannot obtain an IP address from certain routers or
from certain non-Microsoft DHCP servers"
<http://support.microsoft.com/kb/928233>
You might check if there's a firmware update to your routers as this
problem was "solved" by the router manufactures, since it's beneath
Microsoft's dignity to admit that they screwed up.
Jeff Liebermann jeffl@cruzio.com
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Posted by Eric on August 1, 2007, 8:05 pm
I guess Microsoft didn't get the memo about how DHCP should just be a simple
standard and not rocket surgery....
Posted by phil6666 on August 1, 2007, 8:41 pm
OK...now I'm even more confused!!
I already replaced the non-VISTA compatible Netgear router with a
VISTA compatible Belkin!
As I said earlier:
>adapter.
>I just got a VISTA compatible Belkin F5D7230-4 (802.11g) router and the laptop
works fine.
Are you guys saying my XP PC with a Netgear MA101 (802.11b) adapter
won't work with my VISTA PC/Belkin VISTA compatible router????
That's my guess, but I didn't think that would be an issue.
thnx
Posted by Jeff Liebermann on August 2, 2007, 12:23 am
That's because you have presented two issues.
- 802.11b client with 802.11g router.
- Vista compatibility.
There's no such thing as "Vista compatible". There's the lame
Microsoft DHCP glitch, which is easily fixed, but everything else is
the same with XP and Vista. My guess is that "Vista compatible" is a
sales gimick.
- Your XP PC with whatever you own, will work with either the Netgear
or Belkin routers.
- Your Vista PC will not get a DHCP assigned IP address unless this
was fixed in the firmware of either router, *OR* you apply the fix I
mentioned.
However, I suggest that you consider getting something better and
faster than the Netgear MA101. 802.11b only clients tend to slow
everything down on a wireless network. It's not just that the 802.11b
devices are slow, it's that they hog so much airtime that the 802.11g
devices have little time left to move their traffic. I wrote
something on the topic recently:
<http://groups.google.com/group/alt.internet.wireless/msg/5f4025e60ba4c135>
Similar ThreadsPosted
Will 802.11b Adapter Work with 802.11g Router? August 1, 2007, 6:59 pm
Will an 802.11b adapter work with a 802.11n router? January 4, 2008, 1:16 pm
Getting Sprint USB Wireless Network Adapter to work w/ Wireless Router January 13, 2008, 4:37 pm
D-Link DWL-G122 USB adapter doesn't work after reinstalling Win XP, help please? October 31, 2005, 4:51 pm
Getting WPA to work using Netgear WG511T adapter on Windows 98SE system January 23, 2005, 12:29 pm
miniPCI to PCI adapter+ miniPCI wifi card - would it work? January 3, 2008, 2:23 am
How do 2 WLAN Router work together? March 31, 2005, 10:41 pm
advice please on which router will work October 3, 2007, 2:12 pm
USR Router Firmware update - FTP won't work.... October 30, 2004, 10:38 pm
MIMO needs that router & card have it to work?. May 16, 2006, 6:11 am
Linksys router won't work after power loss November 19, 2004, 6:17 am
Can wireless router work without being tied to computer? January 18, 2006, 2:00 am
Does WEP and WPA work with Netgear DG834PN wireless router? June 18, 2006, 3:49 pm
Getting Speedstream 2624 Wireless Router to work? July 12, 2007, 10:32 pm
Netgear draft-n router has to be rebooted everyday to work December 29, 2006, 7:41 pm
