Wireless Networking Wi-Fi Cantenna Advice Wanted
Subject Author Date
Wi-Fi Cantenna Advice Wanted Howie 03-26-06
Posted by Howie on March 26, 2006, 11:22 am
Hello to all and thanks for reading. I am an absolute novice to the
world of Wi-Fi and find the home made "Cantenna" appealing to me but
have not found any info on the net as to how well this type of antenna
really works.
I have hopes of going point to point 1400' to a friends house and
sharing his broadband internet.
Since this will be an experiment I am trying to keep expenses low.
Should I get "dismal" results, that will give me the go ahead signal to
spend what is necessary to do it right.
Any advice for a websites for a complete newbie?
Thanks, Howie
Posted by David Taylor on March 26, 2006, 11:51 am
> really works.
Seriously? You can't have looked far, there's plenty of field shoot
outs and so on that describe peoples experiences. They work well.
If you have clear line of sight that will be no problem whatsoever.
David.
Posted by David Taylor on March 26, 2006, 11:52 am
Sorry, forgot that bit, seriously....
Google "cantenna"
Posted by Jeff Liebermann on March 26, 2006, 1:17 pm
>really works.
How well is measured in decibels of gain. The more gain, the better
the antenna works for increasing range. 6dB increase is double your
distance. 12dB increase is 4 times the distance.
It takes two to tango. If your friend also has a directional antenna
on his wireless router, and you have clear line of sight, then it
probably will be quite an easy link. However, if your friends
wireless router has the insipid stock antenna, or has located his
router where you can't directly see it, you'll have problems. Get
line of sight first.
Since you don't want to spend any money, I'll assume that you have
more time than money available and are interested in building your own
antennas. See:
http://groups.google.com/group/alt.internet.wireless/msg/dd0f9c414b913355
for a list of antenna construction articles.
Another biquad article that I like:
http://www.vallstedt-networks.de/?Fotogalerien/quad2
Simple reflector, see:
http://www.freeantennas.com
1. Get line of sight. It's not going to work if you have trees,
building, hills, or junk in the way.
2. Start with a simple reflector. That will tell you if you have a
chance.
3. I recommend building a biquad instead of a coffee can antenna.
4. Avoid long coax cable runs especially with very small diameter
coax cables. The coax losses are horrible.
5. Building antennas does require some precision. If you're not
familiar with construction techniques, buy a commerical antenna:
http://www.fab-corp.com
6. You may need to calculate if the link will work depending upon
your selection of equipment and antennas. See the FAQ at:
http://en.wikibooks.org/wiki/FAQ_for_alt.internet.wireless/Wi-Fi#Link_Calculations
6. Next time you ask a question, please include what equipment you
have to work with. At both ends of the link. Maker and model.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Posted by Bob on March 26, 2006, 6:25 pm
> >really works.
> antennas. See:
> chance.
Take a look at my web site tin cantenna info:
http://members.cox.net/tulsaalstons/Documents/Tin%20Cantenna%20Made%20With%20Compact%20-%20Dongle%20USB%20Wireless%20Adapter%20.htm
http://members.cox.net/tulsaalstons/my-tin-cantenna2.htm
Bob
Similar ThreadsPosted
Wi-Fi Cantenna Advice Wanted March 26, 2006, 11:22 am
Advice wanted on connecting two houses over 802.11x December 1, 2005, 8:10 am
Asus wl-500gx advice wanted June 14, 2006, 2:57 pm
Advice wanted on Belkin modem/router July 1, 2005, 12:47 pm
Review of Mega-Wave WiFi 12dbi gain antenna wanted December 29, 2004, 9:40 am
Connecting 2 Wifi Networks Via Cantenna April 30, 2007, 2:05 pm
Looking for Wifi and Tivo advice. November 16, 2005, 1:57 pm
Touring the US: WIFI-advice needed!? September 13, 2005, 5:52 pm
need advice on a wifi setup, with a repeater in between.. August 9, 2006, 9:05 pm
Newbie to wifi hotspots, could use some advice July 22, 2007, 2:35 am
Advice on WIFI antenna/adaptor January 23, 2008, 2:23 pm
Hardware Review Website and USB WiFi Adapter advice Needed January 21, 2008, 10:52 pm
Advice on building high-power rural wifi access point October 23, 2007, 3:12 pm
Software Wanted March 21, 2007, 2:11 pm
Networking information wanted January 24, 2007, 6:42 pm
