Wireless Networking Why I can't get Airlink 150N usb wifi to install?
Subject Author Date
Why I can't get Airlink 150N usb wifi to install? dontdont 06-08-08
Posted by on June 8, 2008, 2:04 pm
I bought an Airlink 150N AWLL6070 usb 802.11N adapter at Fry's. $15
on sale, $20 more on sale for the Airlink N router.
Yes I know Airlink is at the bottom of the food chain.
The quick installation guide is rev 1.3.
The install CD does say it is for the 150N.
I open it up and follow the directions, using this under XP
and again under Win2k.
1: Insert usb adapter
2: Windows launches Found New Hardware, cancel that and insert CD.
3: Select Install Driver from autorun screen
4: Click Next at welcome screen
5: Click Next for default destination
6: Click Continue Anyway to accept unverified
(I don't think that showed up)
7: Click Yes want to restart and click Finish
8: On reboot see Found New hardware pop up...
then your are supposed to say yes to install the software...
but the Found New Hardware is never triggered.
I even tried running scan for new hardware and
it says there is nothing new to find.
I uninstall and try it all again, same thing.
The dongle doesn't appear dead, if I ignore that step
8 never happens it is sort of half there, the Airlink
utility that looks for available networks tells me
that it sees a live wifi device out there but it looks
like it is missing the rest of the installation and
trying to get it to use the Airlink network connection
never works, or maybe I've somehow done something
wrong trying to switch from an existing wired connection
to the wireless dongle.
Seems a little unusual to install usb device first and
then software, most mfgrs seem to say "for God's
sake DON'T install the usb until after our software",
so I tried that and it is even worse.
Can anyone think of something dumb I've missed or
something I can try to get this to work? Maybe I've
turned off some essential service, maybe I've turned
off some permission, maybe some bit has been randomly
clobbered somewhere. I've successfully used their G
usb dongles a few years ago.
I sent email to Airlink support and would be very
surprised if anyone ever responds.
Thank you for any suggestions or ideas that will make
this work or even turn up some hints that will lead to a
solution. If anyone knows of a set of steps to be
followed to usually get Airlink, or to switch from wired
to wireless, I'd really appreciate a pointer. I've been
searching the net for hints and not found anything.
Posted by TBerk on June 8, 2008, 3:10 pm
- What happens when you now (after installing said drivers) start the
system and )then_ install the USB device/
Does it 'find' the 150N?
- Did you try in explore the install CD and locate the driver install
app? Perhaps installing it ala carte will be a path of success.
hth,
TBerk
Posted by Jeff Liebermann on June 8, 2008, 3:21 pm
Sigh. You get what you pay for.
Strangely, the Airlink web pile doesn't have that model listed:
Either your directions are different from every other USB device on
the planet, or you can't read very well.
Note: Before installing the utility software, DO NOT insert
the USB adapter into your computer. If the adapter is inserted
already, Windows will detect the adapter and request for a driver.
Click Cancel to quit the wizard and remove the adapter from your
computer.
The probem is that if you shove in the USB gizmo first, and later
install the driver, you end up with two drivers installed. Do
whatever it takes to undo the damage. If you can't uninstall it, and
remove it from the Device Manager (hint: show hidden devices), then
use System Restore to rewind your system back to before you misread
the instructions.
Jeff Liebermann jeffl@cruzio.com
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Posted by LR on June 8, 2008, 3:40 pm
http://www.airlink101.com/download/awll6070.php
The driver download doesn't seem to work though.
Posted by Jeff Liebermann on June 8, 2008, 4:58 pm
The link point back to itself. Not very useful.
The data sheet says:
<http://www.airlink101.com/products/awll6070.php>
"NEW: This product will be released soon."
I was look at:
<http://www.airlinkplus.com>
Which kinda looks like the same company, but obviously is not.
Weird.
Similar ThreadsPosted
Why I can't get Airlink 150N usb wifi to install? June 8, 2008, 2:04 pm
150N USB November 20, 2008, 11:06 am
airlink 101 August 27, 2006, 7:25 am
Are Airlink products any good? December 6, 2004, 5:40 am
Airlink stuff is CRAP!! December 14, 2004, 2:48 am
AirLink AP411W & WRT54G May 2, 2005, 2:28 am
Airlink 10dbi at Frys July 18, 2006, 10:30 pm
airlink 101 usb wireless ethernet card August 27, 2006, 7:26 am
Fry's cheapie: Airlink AWL5025 $15 December 3, 2006, 12:29 am
Fry's airlink 10dbi directional antenna November 11, 2006, 10:20 pm
Question on Airlink AWLL3026 USB wireless adaptor May 25, 2007, 3:25 am
Question on Airlink AR430 Wireless Router June 21, 2008, 4:20 pm
Adelphia Cable Modem and Airlink+ Wireless Router October 27, 2004, 1:23 am
linux firmware hack for Airlink AR315W router? September 18, 2005, 3:19 am
Airlink 10dBi Omni-Directional Antenna for $9.99 in current Frys ad November 16, 2006, 2:48 pm
