Wireless Networking WHR-HP-G54 DNS settings problem
Subject Author Date
WHR-HP-G54 DNS settings problem NotMe 05-19-08
Posted by NotMe on May 19, 2008, 3:07 pm
I have several-HP-G54 units. I'm trying to use one with a Motorola Model
U10C018 cable modem on Charter Communication cable internet. (system config
data follows)
WHR-HP-G54 has been set up using opendns.com
DNS1(Primary) 208.67.222.222 (Manual)
DNS2(Secondary) 208.67.220.220 (Manual)
Somehow the system (which part I don't know) is defaulting to the Charter
DNS
DNS3 66.169.221.10 (Via DHCP)
DNS4 68.113.206.10 (Via DHCP)
I've used these with Charter systems before with success but not with the
U10C018 cable modem.
Contacted Buffalo support and while they have been very helpful in the past
they are unable to explain what's happening or how to address the problem.
I should mention that we had to manually set the MAC Address
00:04:5A:75:D3:5B of the modem in the
WHR-HP-G54 set up process otherwise the connection to the internet was
flaky.
This would not be a problem but I have my grand kids using the net work and
want the added protection I can get from opendns.com.
I currently have the system set up as 'open' and will lock down access once
the DNS problem is fixed.
FWIW I'm in the 'toy' mode and can try most anything this group thinks might
help.
TIA
Model WHR-HP-G54 Ver.1.40 (1.0.37-1.08-1.04)
AirStation NameAP001601D1553E
Operational ModeRouter Mode
WANDHCP
Connection StatusCommunicating
Operation
IP Address 71.15.124.227
Subnet Mask 255.255.255.0
Default Gateway 71.15.124.1 (Via DHCP)
Host Name AP001601D1553E (Manual Setup)
Domain Namesetup (Via DHCP)
MTU Size1500
DHCP Server Address 68.114.37.166
Lease Acquired Time 2008/05/19 09:10:43
Lease Period 2008/05/19 11:25:00
Wired Link100Base-TX (Full-duplex)
MAC Address 00:04:5A:75:D3:5B
LANIP Address 192.168.11.1
DHCP Server Enabled
MAC Address 00:16:01:D1:55:3E
Wireless(802.11g) Wireless Status Enabled
SSID HelloWorld-1
Encryption Mode Not Configured
Wireless Channel 1 Channel (Manual)
125* High Speed ModeEnabled
MAC Address00:16:01:D1:55:3F
Posted by Reinhard Schimek on May 19, 2008, 10:21 pm
It sounds to me that you configure your router correctly, but you
configured your network card to use another DNS server. Go to start then
run. In the box type in cmd, and click ok. You will see a black screen
come up. At the prompt, type: ipconfig /all
Copy what is displayed, and come back paste here so I can see the results.
hope it helps. Reinhard
> data follows)
> DNS
> flaky.
> help.
> TIA
> WANDHCP
> Operation
> MTU Size1500
> DHCP Server Enabled
> SSID HelloWorld-1
Similar ThreadsPosted
WHR-HP-G54 DNS settings problem May 19, 2008, 3:07 pm
Wireless settings problem October 11, 2007, 8:31 pm
DI-524 wireless settings January 6, 2005, 1:29 pm
Losing WPA-PSK settings March 24, 2007, 5:08 am
wireless ip settings November 3, 2007, 8:08 am
lg viewty wap settings January 10, 2008, 2:51 pm
USR2249 Antenna settings. what is what? November 7, 2004, 3:15 am
Can't remove Addon settings? May 24, 2005, 9:36 am
SMC Wireless Card Settings June 28, 2005, 11:08 pm
Wireless router settings September 17, 2005, 10:36 pm
Copy router settings to new PC? August 17, 2006, 12:58 am
dlink router settings October 26, 2006, 3:09 am
Checked the router settings.. June 22, 2007, 9:01 am
USR8054 manual port settings. December 1, 2004, 2:37 pm
WLL-2700 manual/default settings April 17, 2005, 12:14 am
