Wireless Networking WGB and U-WGB
Subject Author Date
WGB and U-WGB tg 07-10-08
---> Re: WGB and U-WGB Aaron Leonard07-11-08
Posted by tg on July 10, 2008, 4:42 pm
Cisco AIR-AG1242AP access point:
1) what's the difference between Workgroup Bridge and Universal Workgroup Bridge?
2) is Universal Workgroup Bridge the same thing as the 'Wireless Distribution
System'
(WDS)?
3) trying to configure the above 1242AP as a wireless bridge to connect to an
O2wireless
box router - the O2 help files refer to a 'Wireless Distribution System' being
allowed to
connect but nothing about a wireless bridge. I need to clarify what a wireless
distribution system really is and whether it's compatible with WGB and U-WGB
Thanks for any pointers.
Posted by Aaron Leonard on July 11, 2008, 2:41 pm
[ adding comp.dcom.sys.cisco because this is Cisco-specific stuff ]
~ Cisco AIR-AG1242AP access point:
~ 1) what's the difference between Workgroup Bridge and Universal Workgroup
Bridge?
Standard "Aironet" Workgroup Bridge mode is a purely Cisco proprietary extension
to 802.11
and only interoperates with Cisco APs. It permits for a WGB to have a large
number of
wired clients behind it.
Universal WGB is essentially a "MAC cloning" scheme, where the WGB will present
its
wired client's MAC as the radio MAC to the AP to which it associates. It only
supports
a single wired client, and (hopefully) should work with non-Cisco APs.
~ 2) is Universal Workgroup Bridge the same thing as the 'Wireless Distribution
System'
~ (WDS)?
Nope, they have nothing to do with each other.
WDS is a scheme on the infrastructure side whereby an AP can act as a common
authenticator
(in the 802.1X sense) / key manager for a set of up to 60 infrastructure APs.
The use of
WDS in the infrastructure should be transparent to clients.
~ 3) trying to configure the above 1242AP as a wireless bridge to connect to an
O2wireless
~ box router - the O2 help files refer to a 'Wireless Distribution System' being
allowed to
~ connect but nothing about a wireless bridge. I need to clarify what a wireless
~ distribution system really is and whether it's compatible with WGB and U-WGB
~ Thanks for any pointers.
I suggest that you state with considerable detail exactly what you are trying to
accomplish.
Stuff like:
- what infrastructure you have (what make / model / software version of APs)
- what encryption/authentication/key management scheme you are or want to be
using
- what kind of wired clients you intend to support behind your WGB
etc.
Hth,
Aaron
Posted by tg on July 11, 2008, 5:54 pm
Aaron thankyou for your really good information, I now understand things a
little clearer.
Now I understand why the only AP I've been able to bridge to is my other Cisco
AP. But
finally - thanks to your advice - I've managed to bridge my Cisco AP to a
non-cisco AP
using Universal Workgroup Bridge. A breakthrough at last. Many thanks again.
Posted by Aaron Leonard on July 14, 2008, 12:56 pm
"tg" wrote:
~ Aaron thankyou for your really good information, I now understand things a
little clearer.
~ Now I understand why the only AP I've been able to bridge to is my other Cisco
AP. But
~ finally - thanks to your advice - I've managed to bridge my Cisco AP to a
non-cisco AP
~ using Universal Workgroup Bridge. A breakthrough at last. Many thanks again
Glad I could help. However, I need to post a correction to some misleading
information
in my previous post:
~ ~ 2) is Universal Workgroup Bridge the same thing as the 'Wireless
~ ~ (WDS)?
~ Nope, they have nothing to do with each other.
~ WDS is a scheme on the infrastructure side whereby an AP can act as a common
authenticator
~ (in the 802.1X sense) / key manager for a set of up to 60 infrastructure APs.
The use of
~ WDS in the infrastructure should be transparent to clients.
Unfortunately, the "WDS" acronym has two meanings. My posting quoted above was
intended
to refer to the (Cisco proprietary) Wireless DOMAIN Services (which we describe
in
http://www.cisco.com/en/US/docs/wireless/access_point/1300/12.2_15_JA/configuration/guide/o13wds.html
etc.)
This has nothing to do with the Wireless DISTRIBUTION service "WDS" which term
is used
by other WLAN industry players. I.e. a scheme by which infrastucture side
connectivity
for the APs is provided wirelessly
(http://en.wikipedia.org/wiki/Wireless_Distribution_System).
This again, is a non-802.11 standard mechanism (and so devices from multiple
vendors will
likely fail to interoperate.) Cisco has several schemes for doing this
(including the
Repeater and Link Role Flexibility features in autonomous IOS APs, and the mesh
scheme
in our centralized architecture), but when we use the term "WDS", we always
refer to
our Wireless DOMAIN Services feature.
Cheers,
Aaron
