Posted by on March 5, 2008, 3:35 pm
I have a unusual problem.
I have a macbook pro with dual boot. (MacOS 10.5.2 & Vista 64bits).
I can access my router from Vista using the wireless built-in card,
but no luck with MacOS.
And before everything was prefect on both sides.
I tried resetting my router to factory defaults with no luck.
I brought my Macbook to the store and they tried to connect on their
hot-spot without any problem!!
I went back at home, formatted the MAC partition, installed MacOS
10.5.1 and I got connected. Then I upgraded to 10.5.2 and lost
connection again.
Why is 10.5.2 doesn't connect at home on my D-Link Dir-625 (only on my
MAC partition) but connects flawlessly everywhere else??
Thanks for your help.
Marc
| Similar Threads | Posted |
| Unable to access router wirelessly | March 5, 2008, 3:35 pm |
| How to connect two routers wirelessly and access internet through the guest router? | July 10, 2007, 6:52 am |
| Reaching access point but unable to connect to the Internet. | March 3, 2007, 2:31 pm |
| Unable to access internet using wireless card Intel 3945abg | February 1, 2008, 12:47 am |
| Unable to login and add security to WRT54G being used as access point/extender | September 28, 2008, 10:17 pm |
| access wirelessly the desktop from laptop | April 2, 2005, 9:03 pm |
| Extending Access Point Range wirelessly | April 30, 2005, 6:14 am |
| Connect 2 Networks using 2 Access Points WIRELESSLY. | December 4, 2007, 9:41 am |
| Linksys SRX(WRT54GX ) unable to connect with another router | June 27, 2005, 8:19 pm |
| Linksys SRX(WRT54GX ) unable to connect with another router | July 1, 2005, 1:06 pm |
| Unable to connect AOL9 to router via wireless | September 12, 2005, 9:55 pm |
| Unable to connect to internet through wireless router | March 15, 2007, 10:45 am |
| connect a wired network to an Access Point wirelessly | August 25, 2005, 12:49 pm |
| Can a WRT54GL and WRT54GS be bridged wirelessly AND still have one act as a wireless access point? | November 8, 2006, 9:54 pm |
| Unable to access wireless network from a laptop / Can from other PC and laptop | October 10, 2006, 9:04 pm |
