Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Keith on July 11, 2008, 10:16 am
Please log in for more thread options Hi Someone recently made up a cable for me to connect an external antenna to my WRT54GL. Unfortunately, the person that did the cable didn't understand the difference between TNC and RP-TNC, so my cable has a TNC male connector on the business end, and my router needs an RP-TNC male. Is there such a thing as a TNC/RP-TNC adapter out there anywhere? I've STFW, but sadly to no avail. Any tips welcomed. | ||||||||||||||||||||||
Posted by Anthony R. Gold on July 11, 2008, 10:47 am
Please log in for more thread options Either slice off the standard TNC plug and replace with an appropriate RP-TNC connector or get 2 pigtails from TNC to N and also RP-TNC to N. Tony | ||||||||||||||||||||||
Posted by Keith on July 11, 2008, 11:53 am
>> STFW, but sadly to no avail. >
> Either slice off the standard TNC plug and replace with an appropriate > RP-TNC connector or get 2 pigtails from TNC to N and also RP-TNC to N. The problem with the first idea is that it seems that RP-TNC connectors here in the UK are rare as hens teeth. I think I shall just return the cable to the guy who made it up and see if he can source the connector. Your second suggestion is excellent, but too expensive for me, as I'm out of work at the moment, and watching the pennies. Cheers! | ||||||||||||||||||||||
Posted by Anthony R. Gold on July 11, 2008, 12:11 pm
>>> STFW, but sadly to no avail. >>
>> Either slice off the standard TNC plug and replace with an appropriate >> RP-TNC connector or get 2 pigtails from TNC to N and also RP-TNC to N. >
> The problem with the first idea is that it seems that RP-TNC connectors > here in the UK are rare as hens teeth. I think I shall just return the > cable to the guy who made it up and see if he can source the connector. Are these the correct gender that you need? http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=2508363778 http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=2508363784 Tony | ||||||||||||||||||||||
Posted by William4 on July 12, 2008, 9:48 am
Please log in for more thread options >> Dear God, they're expensive! B----r that.
Nearly £6 with postage - RS were what £8 odd? I know which I'd go for.
> Keith they're only £3 here: > http://www.wirelesspro.co.uk/product/rptnc_male_crimp_connector_lmr_195/ | ||||||||||||||||||||||
| Similar Threads | Posted |
| Can't start internal wireless adapter after installing a buffalo adapter | August 7, 2007, 6:09 pm |
| mimo XR 802.115 cardbus adapter vs. non-mimo XR adapter | August 1, 2006, 10:44 pm |
| USB adapter | November 7, 2005, 8:48 am |
| TNC/RP-TNC adapter | July 11, 2008, 10:16 am |
| USB Adapter | November 19, 2008, 5:41 pm |
| AT&T 6500G 802.11g adapter | December 3, 2004, 5:12 am |
| What Best USB 54G Adapter for a Desktop? | December 28, 2004, 1:56 am |
| Any recommendations for a USB adapter? | December 31, 2004, 7:46 am |
| Bluetooth Adapter | January 30, 2005, 5:17 pm |
| Best Range for a USB Adapter? | February 25, 2005, 5:48 am |
| DC Adapter question | June 7, 2005, 8:25 pm |
| looking for a usb adapter with sma option | June 21, 2005, 9:28 am |
| USB to Ethernet Adapter-For X-Box | July 16, 2005, 10:43 pm |
| usb adapter cantenna | September 21, 2005, 10:53 pm |
| what type of adapter to use? | December 22, 2005, 11:32 pm |
TNC/RP-TNC adapter
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Hi
> Any tips welcomed.
