Wireless Networking Routing between two wireless networks
Subject Author Date
Routing between two wireless networks tkasprow 04-03-08
Posted by on April 3, 2008, 12:59 pm
Hello
At my house I receive Internet trough WiFi (not very typical). There
is antenna on top of my house and is connected to wireless card in my
desktop PC. I want to create a new wireless network that would cover
my house. Therefore I am trying to find a router that would route
between external WiFi network and my (to be created) home WiFi network
however I cannot locate appropriate hardware.
Could anyone help me with identifing approporiate solution? (the only
thing that comes to my mind so far are two routers that route between
LAN/WiFi but I look for simpler solution)
Thanks in advance
Tomek
Posted by on April 3, 2008, 1:46 pm
On 3 Apr, 18:59, tkasp...@gmail.com wrote:
> Hello
> Thanks in advance
> Tomek
Any of the modular Cisco routers with 2 wireless cards?
Not cheap though.
I am almost sure that one of the 1800 range would do but
I would guess that the wireless cards HWIC.....
would be 500US each (new). Any maybe more for
the chassis and software.
Posted by Bill Kearney on April 3, 2008, 6:54 pm
>> desktop PC.
Change the setup from the antenna on your house to connect directly to a
router, via ethernet. See if your ISP offers such an option. That's your
solution of least hassle, long-term.
Otherwise you could setup your PC to act as a router. Add an ethernet card
to it. Then connect that ethernet card to an access point. Configure the
access point and use it to connect through the PC to the internet. The
downside being that PC will have to be on all the time. That and routing
software setup on the PC is somewhat "less than trivial" if you want it to
be secure.
Check with your ISP about how to use multiple wired PCs in your house. If
they can do that then you're in business.
Posted by P.Schuman on April 5, 2008, 2:17 pm
> Hello
> Thanks in advance
> Tomek
a little more info on what is on the roof
or a link to your WISP would be helpful.
Also - is the wireless card in your PC something standard,
or is the WISP using something "different" ?
Since you already have a WiFi signal broadcasting from your roof
to your PC - then it might cover the rest of the house,
if you can have other WiFi computers connecting to the roof ?
Posted by on April 16, 2008, 11:52 am
wrote:
> > Hello
> > Thanks in advance
> > Tomek
> if you can have other WiFi computers connecting to the roof ?- Ukryj cytow=
any tekst -
> - Poka=BF cytowany tekst -
WISP is very local and website is only in my native language (Polish).
The card in my PC is regular WiFi card linked to an anntena on the
roof. The signal is too faint indors to be of any use. Morover only
the card provided by WISP cann connect (MAC) - they say I can clon the
MAC to a router if I like.
Similar ThreadsPosted
Routing between two wireless networks April 3, 2008, 12:59 pm
Mesh Networks using Ad hoc On Demand Distance Vector (AODV) routing February 7, 2006, 7:05 pm
Wireless Routing December 13, 2005, 2:11 pm
How does wireless routing work? January 14, 2006, 7:52 pm
Wireless to Wired routing help September 23, 2006, 2:33 pm
Can You Help? Routing Through a Hub December 24, 2004, 5:53 pm
WRT54G as AP no routing.. June 22, 2006, 7:17 am
Routing through two DD-WRT's November 23, 2007, 3:38 am
routing protocol February 9, 2008, 3:44 pm
Advice Needed: IP Routing for > 1 IP April 2, 2006, 11:02 am
routing through an internal WRT54G September 18, 2006, 3:30 pm
EOC-3220+ routing problem November 6, 2007, 10:50 pm
Routing problem with two network cards March 19, 2005, 11:27 am
routing problem between ADSL router and wireless router February 27, 2006, 9:58 am
WAP55AGv2 Default Gateway routing issue May 28, 2005, 7:08 pm
