Wireless Networking Replace Mini-PCI Wireless card in HP Ze5375
Subject Author Date
Replace Mini-PCI Wireless card in HP Ze5375 Plan9 02-07-06
Posted by Plan9 on February 7, 2006, 11:32 am
I'd like to get WPA to work on a HP Ze5375 notebook running XP-Home.
It has an internal wireless LAN-Express IEEE 802.11 PCI Adapter which
does not support WPA and according to:
http://forums1.itrc.hp.com/service/forums/questionanswer.do?threadId=955845
HP isn't likely to provide upgrade firmware for WPA support on this
device. I've tried to update the firmware and drivers via the various
PRISM II upgrades (Fujitsu, etc.) and have failed.
What I'd like to do is replace the Lan-Express with a Broadcom card
that HP used in later runs of the Ze5375 or better yet the G version
of the Broadcom card, HP Broadcom 54g Mini PCI, to take advantage of
the G speeds of my WRT54G. Or a newer version of the Intel Mini-PCI
that has WPA and G support. Anyone know if any of these options will
work in the Ze5375? Another option?
Bottom line: I would really like to have WPA support and 801.11g would
be icing on the cake.
--Ben
Similar ThreadsPosted
Replace Mini-PCI Wireless card in HP Ze5375 February 7, 2006, 11:32 am
miniPCI to PCI adapter+ miniPCI wifi card - would it work? January 3, 2008, 2:23 am
Installing antenna on internal wireless MiniPCI card November 27, 2006, 9:56 pm
HP ze2000 versus Intel 2200bg miniPCI card May 4, 2006, 12:27 am
Laptop Wireless miniPCI August 11, 2006, 3:47 pm
replace "non-removable" antennas - Belkin router? November 15, 2004, 9:06 pm
Moving MiniPCI Wireless from Westell 327w to Dell Laptop??? July 1, 2006, 3:27 am
Atheros 5004x miniPCI a/b/g- EEPROM January 11, 2005, 12:06 pm
WRT54G Linksys default antennas replace with 7 dbi antennas May 9, 2005, 10:48 pm
Dell Laptop confuses Linksys Wireless G card as a Dell TrueMobile 1300 WLAN Mini-PCI Card ? November 5, 2005, 10:38 pm
which wireless card January 24, 2005, 12:17 am
SMC Wireless PCI Card August 1, 2005, 6:49 pm
wireless card October 25, 2006, 6:44 am
Wireless Lan Card September 22, 2007, 11:24 am
Need advice on configuring a wireless network using a PDA, wireless router and PC with wireless card October 9, 2007, 3:53 am
