Wireless Networking Re: Need to extend LAN less than mile
Subject Author Date
Re: Need to extend LAN less than mile ps56k 05-17-08
Posted by ps56k on May 17, 2008, 9:08 pm
since you don't have direct wiring between the locations,
you might think about wireless..... - x-posted to that newsgroup
continue at the bottom
Harvey wrote:
> I am not very familiar with all the terminology.
> I have two locations less than a mile apart in a rural area.
> I assume the phone company could (if I knew how/what to ask) make
> appropriate splices to give me two or more pair of copper between the
> two locations.
> Is that what a "leased line" is? Or does that go through the exchange?
> Assuming I could get this copper between the two points, how fast
> could I send data between the two?
> I have an ethernet lan on each end that I want to connect together.
> And of course :-) I want to do it for low cost.
> I would simply use the internet but there is no high speed available
> out there in rural Western Washington State.
> Thank you all very much,
> Harvey.
I have a friend near Randle WA - near Mt. St. Helens... no high speed either
anyway - what do you ultimately want to do ?
and why do you want the locations connected ?
Posted by Harvey on May 17, 2008, 9:25 pm
> > two locations.
> > Harvey.
It is for monitoring 5 cameras. The camera setup is in place and
working over the internet using dial up, but it is too slow. The
picture updates only about every 5 to 40 seconds. I assume that
internet traffic is the variable. Once every two seconds or faster
would be good.
What do you recommend for wireless through a fairly wooded area?
And again can the phone company provide a connection in the existing
buried wiring? They always have extra pairs available, right? Both
locations are on the same dead end road.
Thanks
Posted by ps56k on May 17, 2008, 10:00 pm
>>> the two locations.
>>> exchange?
>>> Harvey.
>> speed either
> would be good.
oops - wooded area - NG - the radio wave signals are absorbed by the
leaves.... :((
Not sure what "wiring" might be available to you in this situation -
cheaply -
BTW - since you indicated that broadband - DSL, cable, ISDN are not avail in
your area
it might even be tough to get a "leased line" - and it will be cost
prohibitive...
A "leased line" is not just renting an extra pair of wires,
it actually is a datacom service that is configured, optimized, monitored,
and $$$.
And yes - they usually are a hub & spoke arrangement with say 2 points near
each other
actually going all the way back to the telco exchange for the "electronics"
portion.
Any other options ??
Is this on your property - is there a fence or other "path"
where you might be able to string some cable ?
Posted by Jeff Liebermann on May 17, 2008, 10:31 pm
On Sat, 17 May 2008 21:00:59 -0500, "ps56k"
>leaves.... :((
Some frequencies have problems going through water. 900MHz wireless
penetrates leaves (not trunks) quite nicely. Less than a mile is
easy. Worked great for Metricom (Ricochet). See:
<http://www.avalanwireless.com>
<http://www.vecima.com/rider.php>
<http://www.freewave.com>
<http://www.trangobroadband.com/wireless_products/m900s.shtml>
<http://www.streakwave.com/items.asp?Cc=CB-ODU-900MHz>
<http://www.ubnt.com/products/xr9.php>
and others. One catch is that the throughput is rather limited.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831-336-2558 jeffl@comix.santa-cruz.ca.us
# http://802.11junk.com jeffl@cruzio.com
# http://www.LearnByDestroying.com AE6KS
Posted by glen herrmannsfeldt on May 18, 2008, 12:59 am
ps56k wrote:
(snip)
> situation - cheaply - BTW - since you indicated that
> your area it might even be tough to get a "leased line" -
> and it will be cost prohibitive...
> optimized, monitored, and $$$.
I believe in some cases you can buy (rent) a pair of wires
with no electronics in between. It is sometimes done for
alarm companies. It might be that it is harder than it
used to be, as phone companies want to be in the datacom
business. I know public schools that do it for their T1
lines instead of leasing T1 lines. (For schools close enough
to the district office or to other schools.) Libraries
might also be able to do it.
-- glen
Similar ThreadsPosted
Re: Need to extend LAN less than mile May 17, 2008, 9:08 pm
7 Mile 802.11b in the Snow August 7, 2005, 12:13 pm
Going the next Quarter Mile... January 21, 2007, 2:22 am
10 mile point to maultipoint March 28, 2005, 8:16 pm
3.5 MILE WIRELESS BRIDGE August 27, 2005, 4:46 am
3 mile wifi hookup October 5, 2006, 3:10 pm
Spanning two houses 1/3 mile apart February 7, 2007, 10:44 am
1.5 mile wireless setup question September 22, 2005, 12:09 pm
Look at This. Would This Work? 1 Mile Home Wireless October 26, 2005, 3:01 am
Trimble 3 mile blue tooth gear May 10, 2006, 3:11 am
Need help on choosing equipment for 2.5 mile wireless link November 28, 2007, 11:44 pm
Big Antenna Projects - Multi MILE Range September 5, 2008, 11:03 am
Help - How can I extend my wifi? March 7, 2007, 2:57 pm
Video Of Record breaking 125 Mile WiFi Link August 10, 2005, 3:30 pm
re: Confused by how to extend (to Tony) January 21, 2005, 5:18 am
