Wireless Networking Re: Is there any harmful effect from wifi (802.11.x) radiation? Any definitive proof?
Subject Author Date
Re: Is there any harmful effect from wifi (802.11.x) radiation? Any definitive proof? Bert Hyman 09-25-08
Posted by Bert Hyman on September 25, 2008, 10:59 am
dcs@lumbercartel.com (D. C. Sessions) wrote in
> Penang wrote:
>> Is there any _PROVEN_ harmful effect stemming from the wireless
>> radiation of WIFI, be it in the 2.4GHz band (for 802.11b and
>> 802.11g) and in the 5GHz band (for 802.11n) ?
>> Although I am part of the team deploying the city-wide wifi
>> coverage, I want to be sure that what I am doing would NOT cause
>> any harmful effect to the people of this city.
> The frequencies used for WiFi are the same as those used for mobile
> telephones.
Not really. Phones generally operate in two bands, 800-900Mhz and
1800-1900Mhz. These numbers are vague enough to cover the US and the
rest of the world, and GSM and whatever they call the CDMA services
popular in the US. The data services are often elsewhere, but not at
2.4GHz or 5GHz, so far as I know.
> The number of telephones obviously *vastly* exceeds the number of
> WiFi hotpoints, they have the same transmit power, and they are
> located closer to people.
But WiFi APs and computer WiFi NICs radiate continuously, while phones
will transmit only while in a call, or make periodic short
transmissions while inactive. Radiation from a cell transmitters will
probably be continuous though.
As to proximity, your PC's NIC might be sitting on your lap, and
depending on where you are, the AP might be hanging on the ceiling,
directly overhead.
All that said, I have no reluctance to carry a cellphone in my pocket
or use it whenever I need to, nor to use my WiFi equipped laptop for
hours at a time.
Bert Hyman | St. Paul, MN | bert@iphouse.com
Posted by Jeff Liebermann on September 25, 2008, 2:29 pm
Wrong on all counts. 802.11 has a specific duty cycle which varies by
the type of traffic. When there's no traffic, all you see are 10
short beacons per second and some other broadcast traffic (mostly ARP
requests). When saturated at full bandwidth (i.e. downloading), there
has to be spaces between transmissions or there's no way to create a
shared channel system. The timing varies but typical is 50% (which
shows up as a the conventional wisdom of TCP thruput is equal to about
50% of the data rate). So, the worst case duty cycle for Wi-Fi is
about 50% and more typically (my guess) is about 1%.
Cell phones have different timing schemes but basically they can't be
on the air all the time or your battery won't last very long. GSM has
8 time slots, so you automatically have a 12.5% tx duty cycle.
They are also required to have adaptive power control to reduce
handset tx power depending on the cell sites received signal strength.
In general, todays handsets cannot output more than perhaps 250
milliwatts and tend to typically operate in the 50 mw region. If your
handset has a diagnostic mode, you can possibly display the actual
value.
My guess(tm) is that the typical cell phone averages about 50mw RF
with a 15% duty cycle.
Radiation from a cell site is not continuous but is close. There are
usually multiple 250 watt power amplifiers. Each user gets up to 2
watt of RF from the cell site per channel (varies with service and
band). If there are 100 active users, the cell site is spewing up to
200 watts. If there are none, such as might happen at night, the cell
site is spewing next to nothing. The 2 watt carriers are also subject
to the same power control requirement as the handset and can be much
less power output. Electricity to run a cell site is expensive and
vendors are always trying to save on power. You can be sure they're
running as economically as possible.
>directly overhead.
Yep. Think inverse square law. Double the distance and you get 1/4th
the exposure. Distance is far more important the power.
>hours at a time.
Hmmm... You need a personal RF safety dosimeter:
<http://www.satimo.fr/eng/index.php?categoryid=140> (top 2 products)
<http://www.narda-sts.us/products_personal_main.php>
Paranoia sells well.
Jeff Liebermann jeffl@cruzio.com
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Similar ThreadsPosted
Re: Is there any harmful effect from wifi (802.11.x) radiation? Any definitive proof? September 25, 2008, 10:59 am
Re: Is there any harmful effect from wifi (802.11.x) radiation? Any definitive proof? September 25, 2008, 8:58 pm
Re: Is there any harmful effect from wifi (802.11.x) radiation? Any definitive proof? September 26, 2008, 3:04 pm
Re: Is there any harmful effect from wifi (802.11.x) radiation? Any definitive proof? September 27, 2008, 4:35 pm
Re: Is there any harmful effect from wifi (802.11.x) radiation? Any definitive proof? September 29, 2008, 4:52 am
Re: Is there any harmful effect from wifi (802.11.x) radiation? Any definitive proof? September 30, 2008, 12:39 pm
Re: Is there any harmful effect from wifi (802.11.x) radiation? Any definitive proof? September 30, 2008, 6:36 pm
Re: Is there any harmful effect from wifi (802.11.x) radiation? Any definitive proof? September 30, 2008, 10:52 pm
Re: Is there any harmful effect from wifi (802.11.x) radiation? Any definitive proof? October 2, 2008, 8:22 pm
Re: Is there any harmful effect from wifi (802.11.x) radiation? Any definitive proof? October 5, 2008, 10:34 am
Bomb proof walls. Not a joke! May 10, 2006, 12:18 pm
19db Omni Antenna - No Effect October 17, 2007, 10:22 pm
How seo effect search engines results ? December 22, 2007, 8:51 pm
Dramatic (bad) effect of power-saving mode April 3, 2006, 3:48 pm
USB mouse cable has an effect on signal strength May 24, 2006, 4:03 am
