Wireless Networking Re: How add external wifi antena to laptop?
Subject Author Date
Re: How add external wifi antena to laptop? zaplen 07-18-08
Posted by on July 18, 2008, 1:29 am
what i did was pick up a good used taxi antenna with a 30 foot cable
and a magnetic base that sticks to the car roof (it's about 3 feet tall
from base to tip). i put that on the roof of my house and ran the cord
down to my bedroom where my laptop is. i put an alligator clip on the end
of the cable and then cut the end of my pcmcia wireless card carefully
to expose the spot where the antenna is located and attach the alligator
clip. i pick up signals over a good quarter of the city now, several
hundred apis - unfortunately most of them locked out, although there are
still quite a few open ones still out there.
> From: me@privacy.net
>How can I add and external wifi antenna to this laptop?
>Want to get the antenna up much higher than what the
>built in antennas will be
Similar ThreadsPosted
How add external wifi antena to laptop? July 3, 2008, 3:00 pm
Re: How add external wifi antena to laptop? July 18, 2008, 1:29 am
wifi antena January 9, 2006, 7:43 pm
Help with Laptop, external antenna, etc, Please November 6, 2005, 3:19 am
Re: External Wifi Antenna January 14, 2008, 9:40 am
PCMCIA WiFi card with external ant? June 18, 2005, 12:52 am
Antena powyzej 20 dB na 5GHz September 11, 2005, 10:30 pm
What external WIFI antenna for RV or small apartment? February 7, 2008, 11:31 am
Wrt54gl Router Antena Adapter Question April 8, 2007, 10:56 pm
External antenna connector on a Dell 1450 wifi card September 15, 2007, 6:59 am
Connect a Laptop via Wifi and a VoiP to Laptop via RJ45 September 11, 2007, 10:28 am
Laptop wifi problem - wifi will not access IE but wired nic will - any ideas plaese? April 3, 2005, 3:13 pm
Laptop WiFi Problem, wired NIC works WiFi does not - any ideas please? April 3, 2005, 2:39 pm
WiFi Access using my laptop as a wifi router January 31, 2007, 4:30 pm
Wifi to only one laptop ques?? June 1, 2005, 10:24 pm
