Wireless Networking Re: External Wifi Antenna
Subject Author Date
Re: External Wifi Antenna Bill Kearney 01-14-08
Posted by Bill Kearney on January 14, 2008, 9:40 am
> Bingo I am on line great signal strength etc. The only problem is I have
> to click repair every so often from the icon that represents my network
> from the windows network dialog box.
Sounds like the DHCP lease is timing out. Determining the source of the
problem would depend on how the leases are being distributed. Is your
router setting up it's own DHCP? Or is it acting as a relay back to the
WiFi network? If it's acting as a relay then source Wifi network may not
have a large enough DHCP range. It may be running out of addresses due to
you and everyone else trying to connect.
At this point your conversation is probably better continued in the
alt.internet.wireless newsgroup
Posted by Bill Kearney on January 14, 2008, 7:04 pm
> Another possible DHCP problem is Comcast Internet, which doesn't work
> well with some wireless routers. Check for updated firmware and/or a
> different brand of wireless router.
Which is unlikely to be useful advice in this particular situation.
Similar ThreadsPosted
Re: External Wifi Antenna January 14, 2008, 9:40 am
What external WIFI antenna for RV or small apartment? February 7, 2008, 11:31 am
External antenna connector on a Dell 1450 wifi card September 15, 2007, 6:59 am
RG-58U for external antenna October 2, 2005, 12:45 pm
AP External Antenna question? December 12, 2004, 8:09 pm
pcmcia with external antenna December 30, 2004, 4:05 am
WRT54GS and external antenna... March 1, 2005, 3:16 pm
External antenna for HP Notebook? June 1, 2005, 3:33 am
PCMCIA with external antenna September 6, 2005, 1:54 am
Help with Laptop, external antenna, etc, Please November 6, 2005, 3:19 am
Wi-Spy with an external antenna connector April 5, 2006, 8:19 pm
USB Adapter With External Antenna January 24, 2007, 1:12 am
External antenna on Sitcom WL 172 October 6, 2007, 11:43 am
Help with belkin external antenna December 5, 2007, 7:04 pm
Need external antenna for WRT54GL March 1, 2008, 12:49 pm
