Posted by P.Schuman on March 25, 2008, 1:13 pm
> DSL modem + router WAN lights - winking out
> Running the ATT supplied Speedstream 5100a DSL modem
> that is attached to our Linksys BEFSR41 (v1) router running 1.45.7
> firmware -
> Everything has been nice and rock solid.
> Recently - I noticed that things were slow.
> In looking at the DSL modem & router, that are sitting next to each other,
> I noticed the following...
> Every once in awhile,
> the Linksys BEFSR41 router "WAN" column of LEDs
> and the single "Ethernet" LED on the Speedstream 5100a modem
> winks out, and then come back on.
> I've looked in the router logs, but don't see anything.
> I thought maybe the cable - so swapped for a new Cat6 cable,
> no change. Then, to view the stats on the DSL modem,
> I disconnected the cable between the DSL modem & router,
> and added a small 10/100 switch to be able to connect a laptop
> to browse the DSL modem stats....
> SO - I un-plugged the cable from the router, plugged it into the switch,
> along with adding a short cable from the switch back to the router
> and then a cable from the switch to a laptop.
> No errors reported for the DSL, ATM, or Ethernet.
> BUT - AMAZING - no more probs, AND the www.Speakeasy.com speed test is the
> fastest we've seen.
> HUH - the direct connection between the DSL modem + router
> tends to show some intermittent (unreported) Ethernet "wink" problems,
> but adding a small 10/100 switch betweem them (using same cables)
> tends to make the problem go away ???????????????
> Has anyone else ever seen this anomoly of "winking" ?
> "If everything seems to be going well,
> you have obviously overlooked something." - Steven Wright
| Similar Threads | Posted |
| Re: Ethernet winks on DSL modem & router | March 25, 2008, 1:13 pm |
| smc7004awbr and Alcatel Spedtouch Pro ethernet modem | March 16, 2006, 2:26 pm |
| Setting up wireless networking / Internet connection sharing thru ethernet (not cable modem) | January 14, 2006, 6:38 am |
| Cable Modem > Router > Vonage Modem > Wireless Print Server | July 30, 2007, 10:51 am |
| Cable modem and dsl modem/router | February 11, 2007, 3:17 pm |
| wireless router connecting to ethernet router | July 14, 2005, 4:24 pm |
| Re: Cable modem --> wireless router --> wired router --> computer. | September 9, 2007, 10:42 pm |
| [How to] wireless network: modem/router + wifi router | January 9, 2007, 9:23 am |
| Wireless AND ethernet to same router | February 5, 2006, 6:29 pm |
| Can wifi router become a "ethernet bridge"? | May 16, 2007, 6:31 pm |
| D-Link router - Ethernet works but wireless does not | July 19, 2006, 10:15 am |
| Is Ethernet input to wirelss router encrypted? | December 16, 2006, 11:53 am |
| How to connect ethernet devices to an existing wireless router network | September 2, 2005, 1:31 pm |
| Wireless router/modem help | January 10, 2005, 4:26 pm |
| Small modem router | September 20, 2005, 12:26 pm |
> firmware -
> fastest we've seen.
