Wireless Networking Problem with ftp on Powerbook with airport card
Subject Author Date
Problem with ftp on Powerbook with airport card lee 12-15-05
Posted by lee on December 15, 2005, 9:36 am
I have a wireless network providing broadband to a windows PC and a Mac
OS X laptop with airport card. My router has an in-built firewall.
When I try to upload files to a web server from the Mac the program
usually freezes, whether I am running ftp from a terminal, or using an
ftp program called Fetch, and whether PASV is enabled or disabled.
My PC has no problem uploading files to a web server.
When I connect the Mac to the PC with an ethernet cable, I can transfer
files from the ftp server running on the Mac over to the PC, but when I
try to do the same over the wireless network, the ftp program on the PC
connects but freezes waiting for directory listing data from the Mac.
I have also found my Mac to have trouble uploading files over the
wireless network using a web based interface with http, and for some
sites to have network problems when accessed from the Mac when those
same sites connect straight away from the PC.
I would be very grateful if anyone had any insight as to what is
causing my networking problems.
Lee.
Posted by Fred McKenzie on December 17, 2005, 12:29 pm
Lee-
There could be some seemingly-trivial error or disagreement in the
configuration of communications parameters for the wireless network,
either in the base station or in the Airport card.
A more likely cause of the problem might be a nearby teenager with a
cordless phone that works in the 2400 MHz (2.4 GHz) band. Such phones
have been known to cause serious interference to 802.11b and g wireless
systems.
If you live in a dense neighborhood or apartment building, several
neighbors with wireless networks might all be on the same channel as
yours. You could try changing to one several channels away from the one
currently in use.
Microwave ovens can also interfere, but not likely as often.
Fred
Similar ThreadsPosted
Problem with ftp on Powerbook with airport card December 15, 2005, 9:36 am
WPA on Quickertek(Ralink) card on Mac Powerbook not working April 6, 2008, 5:56 pm
Updated software, Quickertek PowerBook WiFi PCMCIA card March 11, 2008, 11:15 am
Did kismac break my Macbook's Airport card? October 21, 2006, 4:27 pm
XPSP2 and MAC Airport AP Problem February 9, 2005, 2:07 pm
Airport Express Win XP Pro SP2 installation problem. February 3, 2005, 5:06 pm
Airport extreme network problem June 9, 2007, 7:12 am
Issues in connecting wirelessly with Mac Powerbook and Linksys Router August 22, 2007, 12:51 am
Linksys BEFW11S4 - DHCP Assigning public instead of private IP for Powerbook G4 May 9, 2005, 8:31 am
Belkin Pre-N Router and Mac Powerbook: Any good way to increase signal strength? February 1, 2006, 3:24 pm
problem with Laptop B card June 5, 2005, 10:25 am
Solution: WPA problem with wireless card December 15, 2004, 8:03 am
Wireless card and shutdown problem January 4, 2005, 3:18 am
BT Wireless network card problem February 11, 2005, 10:13 pm
Internet problem with wireless card May 10, 2006, 1:04 am
