Wireless Networking Possible? PC as gateway to Internet for USB access point/wifi card
Subject Author Date
Possible? PC as gateway to Internet for USB access point/wifi card CraiginNJ 08-18-08
Posted by CraiginNJ on August 18, 2008, 3:54 pm
Is it possible for a Windows XP PC's LAN connection to be used by a
few other PC's via wifi to a USB wifi card like the D-Link DWA-160?
Here's the connectivity map:
multiple PC's <---> wifi <---> USB wifi card acting as an
access point <---> Windows XP PC running some kind of .exe or java
packet forwarding software <---> hardwired LAN <---> Internet
One constraint is that I want to do this without "installing"
software, but I can run an .exe or java software that I carry with me
on a USB memory stick. There's no need to leave anything permanent,
as I'd only need this wifi access for other people in the room
temporarily during meetings.
The reason I can't just directly connect a wifi access point directly
to the LAN is that a user must log into the PC to access the LAN and
Internet. Direct connections to the Internet are prohibited. But
after logging onto the PC that PC can access the Internet via the LAN,
so in theory any laptops that use that PC as a gateway could have
Internet access though it, too.
I seem to recall doing something like that a decade ago, just using a
very short and simple java program to receive IP packets and forward
them on, & vice versa, but we were using a pair of LAN cards in a PC.
I was hoping that there might now might be a turnkey wifi USB solution
on the market to do all this. Is there?
Posted by Bill Kearney on August 18, 2008, 10:41 pm
In theory this is a great way to get your ass fired. They have the
network set up that way for a reason. You're talking about completely
circumventing that. Good luck with your job search.
Posted by CraiginNJ on August 19, 2008, 8:10 am
Bill, please take the time to ask the facts about a situation before
you start throwing unwarranted insults like that.
By using using the PC as a gateway, this would be in full compliance
with their guidelines of enabling internet access to visitor PC's with
the existing network protections (password-restricted login, antivirus/
antispyware, firewall, etc.) at no incremental cost or effort on their
part, with their knowledge and approval.
If you have any constructive ideas instead, I'd welcome them.
> =A0> Direct connections to the Internet are prohibited. =A0 But
> In theory this is a great way to get your ass fired. =A0They have the
> network set up that way for a reason. =A0You're talking about completely
> circumventing that. =A0Good luck with your job search.
Posted by Bill Kearney on August 19, 2008, 3:29 pm
Leave out the facts in the first place and speculation is all you encourage.
And you have ASKED THEM THIS? Or you're just thinking "they'd be ok
with it"?
Having designed, set up and run quite a lot of networks I'd be hard
pressed to even begin to trust letting users set up what you're
suggesting. What would be the point of having the existing login
requirements only to allow something like what you're suggesting?
And I made a constructive one, ASK before doing something like this. If
you have, and they've agreed but haven't offered an approved solution
then one could question whether they know what they're doing.
As for insults, puh-leeze, get a thicker skin. If you think that's
being insulting then you're in for trouble trying to ask questions online.
Posted by Harry331 on August 20, 2008, 1:23 am
CraiginNJ wrote...
Would a WiFi hotspot serve your purpose for a login?
>Internet.
Login PC ? via what protocol ? via Remote Desktop ? via http ?
via telnet ? via ssh ?
Login is a client/server process. And you think you can login a PC
without installing software ? And you are talking a vanilla PC
with Windoz? Incredible!!!
Maybe you can run a proxy server on your PC.
And your guests can setup their browsers to point to your PC as the
proxy server. But again you need to install a proxy server on your PC.
Then you are the expert. You already have had a solution yourself.
Similar ThreadsPosted
Possible? PC as gateway to Internet for USB access point/wifi card August 18, 2008, 3:54 pm
Sharing internet access with other laptops (Verizon card or pay WIFI) July 14, 2007, 6:05 pm
Unable to access internet using wireless card Intel 3945abg February 1, 2008, 12:47 am
Belkin Cable/DSL Gateway Router 802.11b need the best Wireless card October 29, 2004, 5:30 pm
Belkin Cable/DSL Gateway Router 802.11b need the best Wireless card October 29, 2004, 7:02 pm
disable internet gateway January 21, 2007, 2:00 pm
internet gateway slow 1.0 bit/sec February 21, 2007, 8:25 pm
Repeater? Gateway? Access point? June 28, 2006, 10:10 pm
Turn your PC into web-managed wireless access gateway January 4, 2005, 5:44 am
Set up a WRT54G gateway/router as an access point October 3, 2005, 3:16 am
UPNP Internet Gateway keeps dropping with Belkin WiFi Router April 21, 2006, 7:27 am
Internet problem with wireless card May 10, 2006, 1:04 am
PC Card access (Verizon, Sprint, etc.) May 2, 2007, 11:16 pm
RT2500 Wireless Card "Losing Internet" February 4, 2006, 11:42 pm
Wireless Internet PC Card For 64Bit Windows XP Pro (Maybe OT) May 30, 2006, 5:49 pm
