Wireless Networking Output power Linksys Router
Subject Author Date
Output power Linksys Router Oscar Dres 04-26-07
Posted by Oscar Dres on April 26, 2007, 8:51 pm
Hello,
I would like to know what is the maximum Transmit power (Ximit) a
Linksys wrt54gl router
can handle before you shorten the lifetime or whether you should start
using cooling.
I have set mine now to 67 mW, but would like to increase it.
I also would like to know which setting is recommended and which setting
is the most ideal (concerning range, noise and heat generation)
Greetings Oscar
Posted by Tony Hwang on April 26, 2007, 11:45 pm
Oscar Dres wrote:
> Hello,
> using cooling.
> Greetings Oscar
First do the maath to see how much power increse is need to doulbe the
signal strength on paper. If increasing range is he goal I'd rather
dabble with higher gain antenna(does not cost any extra energy!)
Posted by Jeff Liebermann on April 27, 2007, 12:10 am
>using cooling.
Been there. About 100mw is the limit for normal room temperatures. If
you're going to run it outside, or have the router enclosed in an
airtight box, somewhat less. I've seen them smoke the power amplifier
chip when run at 250mw, which is the absolute maximum. There's also
considerable distortion in the AM part of the xmit signal at much over
150mw.
<http://explorer.cyberstreet.com/wrt54g/WRT54g-spectraloutput.html>
You can probably go to 100mw without much risk. Note that some of the
2-wire wireless routers are shipping set to 400mw tx power.
Add xmit distortion as another criteria. I would say that 100mw is a
good compromise.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831-336-2558 jeffl@comix.santa-cruz.ca.us
# http://802.11junk.com jeffl@cruzio.com
# http://www.LearnByDestroying.com AE6KS
Posted by c24 on April 27, 2007, 1:52 am
> Hello,
> using cooling.
> Greetings Oscar
The radio adapters available in the market from AP manufacturers like
Linksys have a maximum value of TX-power. I am about 99.9% sure that
the WRT54GL's max power is 100mW (others like D-Link, Netgear etc fix
it to 30mW).
At a 100mW TX-power, you shouldn't have cooling issues, unless if you
are installing this under abnormal conditions like sunny outdoors, or
in an outdoor enclosure without ventilation.
Also, the heating issues arise due to the processor performance, and
only to a negligible extent the 802.11/WLAN radio.
Hope that helps
c24 / www.confero24.com
Posted by Peter Crosland on April 27, 2007, 2:39 pm
>> start using cooling.
>> setting is the most ideal (concerning range, noise and heat
>> generation)
>> Greetings Oscar
> it to 30mW).
> Hope that helps
The OP should also understand that the increase between 67mw and 100mw is
going to have a negligible effect on the performance of his network.
Peter Crosland
Similar ThreadsPosted
Output power Linksys Router April 26, 2007, 8:51 pm
wifi power output November 29, 2004, 8:15 am
WRT54GS Low output power - New out of box December 7, 2004, 11:58 pm
Can you adjust the output power on Senao APs? January 17, 2005, 10:26 pm
linksys wet11b TX output management March 12, 2005, 11:40 am
Linksys router won't work after power loss November 19, 2004, 6:17 am
Power supply for Linksys Wireless Router April 4, 2008, 3:52 pm
output of one antenna when other is off November 15, 2004, 3:47 pm
Output from pinging in MS-DOS window. What does it mean? December 10, 2004, 11:26 am
PC Screen Output to TV via Wifi March 18, 2005, 2:39 pm
OLSRd debug output January 17, 2007, 7:15 am
dlink 810 MPI card TX output configuration March 12, 2005, 11:38 am
Linksys Wap 11 Power Adapter June 20, 2006, 4:33 pm
LINKSYS WAG54GS RF power out December 12, 2006, 11:02 am
Linksys WRT54G power adapter? March 9, 2006, 2:00 pm
