Wireless Networking Netgear WNR854B question
Subject Author Date
Netgear WNR854B question MarkF 03-04-08
Posted by MarkF on March 4, 2008, 9:51 am
Does anyone use this?
A little (quick) background.
Last night my Linksys WRT150N router started doing what it has done
periodically over the last year - refusing to connect until I
completely reset to Factory defaults and then re-entered my settings.
However, last night nothing I did managed to get it to work any more.
I ran out and bought the Netgear WNR384B Next Rangemax router since I
needed the connection ASAP.
When I got home the Linksys was working, and has been stable for a
while. So before I opened the Netgear, I decided to check the reviews,
and was appalled by what I found. However, these were reviews that
were years old and many firmware updates have been issued - including
one just a week or so ago.
I probably will return it - since it is still unopened - but before I
do I was wondering if anyone here has any experience with this unit,
(version 2), especially with the Feb 2008 firmware update.
Similar ThreadsPosted
Netgear WNR854B question March 4, 2008, 9:51 am
NetGear WPN824v2 Question March 11, 2006, 4:20 pm
Netgear router question September 23, 2006, 8:33 pm
Simple question on netgear router July 2, 2007, 6:12 pm
WinXP SP2 + Netgear MA111v2 configuration question(s)??? February 6, 2006, 9:43 pm
novice question on Netgear wifi adsl Modem-router October 7, 2005, 11:34 pm
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good you are, April 22, 2005, 7:19 pm
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good you are, May 1, 2005, 2:40 pm
NETGEAR WG311T Only Connects to Netgear Networks October 26, 2004, 8:16 am
Setting up a web server with Netgear WGT 624 and Netgear 632 September 21, 2005, 12:53 am
Netgear WGPS606 <-> Netgear WGT624 July 19, 2006, 2:10 pm
Netgear help please March 21, 2007, 12:36 pm
Netgear Bridge 802.11g October 19, 2004, 2:12 am
New Netgear router May 14, 2005, 3:04 am
ME102 Netgear WAP November 15, 2004, 5:12 am
