Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by sacljr on March 19, 2006, 2:52 pm
Hi, I orginally had a gateway router used with PC and laptop which quit working after a couple years. I recently bought Lynksis Wireless-G broadband router at Best Buy. The Geek Squad guy there told me I should have encryption set-up and they could come out to my house for $160 to set up. Would it be that difficult for me to set up myself? I'm pretty novice. ISP is SBC DSL. Can anyone guide me with set up? I'm positive SBC won' t offer any assistance and not sure if Lynksis will. Thanks for any help! Much appreciated! Lisa | ||||||||||||||||||||||||||||
Posted by simon on March 19, 2006, 5:06 pm
Please log in for more thread options Read the instructions you got with it as they give detiled information. If you have no intention of learning then you might aswel pay. | ||||||||||||||||||||||||||||
Posted by Jonathan L. Parker on March 20, 2006, 6:02 am
sacljr wrote: > I recently bought [a Linksys] Wireless-G broadband
> router at Best Buy. The Geek Squad guy there told me I should have > encryption set up and they could come out to my house for $160 to set [it] up. > Would it be that difficult for me to set up myself? Reminds me of an old joke. Guy drives into a mechanic's shop in a car that's running like it's on its last legs. He asks the mechanic if he can do anything, and the mechanic picks up a screwdriver, lifts the hood, and gives a screw in the engine compartment a quarter-turn, whereupon the car starts purring like a kitten. "Gee, thanks" says the astonished driver. "What do I owe you?" "That'll be $20" replies the mechanic. "What? $20 just for turning a screw?" the driver protests. The mechanic answers "No, I only charged you a nickel for turning the screw. The other $19.95 was for knowing which one it was." As for how this applies to your situation, well, it depends on how dirty you're willing to get your hands (figuratively, of course). If I were like you and I'd never done this before (by the way, does this mean you *didn't* have encryption enabled on the router you bought this one to replace? Shame on you!) I think I'd invest maybe one quiet evening perusing the router's owner's manual and then perhaps taking a shot or two at actually enabling encryption on the router and your computer's wireless adapter to see if I could get it working before throwing in the towel and calling in the geeks. I believe the odds are pretty good that anyone smart enough to use a computer, and who can read at maybe an eighth-grade level, can do it. If you decide you'd rather pick up the phone and pull out the credit card, well, it's your money, so it's your choice. Just remember that you'll be paying the geeks that $160 not for actually turning the screwdriver-or, more correctly, banging on the keyboard, but for knowing-and having taken the time to learn-what to bang out. Incidentally, the Geek Squad guy is right that you need to do this, especially if you're going to use the router to access your broadband, since anyone within range of your router can use your connection if you don't. So if you decide you really don't want to slog through learning how to do it yourself, it's best that you bite the bullet and hire the job out. Either way, get it done *before* you fire up the router with the broadband modem plugged into it. | ||||||||||||||||||||||||||||
Posted by Derek Broughton on March 20, 2006, 8:20 am
Jonathan L. Parker wrote: > Incidentally, the Geek Squad guy is right that you need to do this,
> especially if you're going to use the router to access your broadband, > since anyone within range of your router can use your connection if you > don't. So if you decide you really don't want to slog through learning > how to do it yourself, it's best that you bite the bullet and hire the > job out. Either way, get it done before you fire up the router with > the broadband modem plugged into it. I'd add the caveat that if they're not prepared to configure WPA (& then tell you how to set your own keys), then you might as well not do it. WEP is simply too easy to break. -- derek | ||||||||||||||||||||||||||||
Posted by Rico on March 20, 2006, 11:40 am
>working after a couple years. I recently bought Lynksis Wireless-G broadband >router at Best Buy. The Geek Squad guy there told me I should have >encryption set-up and they could come out to my house for $160 to set up. >Would it be that difficult for me to set up myself? No, the booklet that was included by linksys with your new WAP has pretty good instructions on how to do this. In this case it isn't rocket science. > I'm pretty novice. ISP
>is SBC DSL. Can anyone guide me with set up? I'm positive SBC won' t offer >any assistance and not sure if Lynksis will. Actually linksys is very helpful, but the wait on the phone is long. You really can do this yourself. No need for a Geek nor do you need to become one. > Thanks for any help! Much
>appreciated! Lisa First suggestion, just get everything wired up per linksys instructions (in booklet) and make sure with no encryption that you have everything working. Then once you have a good known point of reference, add in the encryption. Note you do need to do this or have it done. Also make sure you alter the pasphrase to log into the Wireless Router. At first it will be " admin ", the reason is EVERY one who would want ot 'break' into your network knows the factory default, so change it. Pick something easy for you to remember or even jot it down somewhere that you won't misplace it (i used a sticky note and have it taped to the bottom of my router). The router can be contacted with your web browser, use an ethernet cable - looks like the cord from the phone to the wall, but connectors on the end are bigger - to connect to the router to do this stuff, at http://192.168.1.1 leave the user name blank and put admin in for the password. Try it this stuff can be fun to learn, and vastly cheaper then Geek Squad. Even if you mess this up, it is easy to undo and try again. Just follow the instructions step by step. fundamentalism, fundamentally wrong. | ||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Need Encryption Set-up Advice | March 19, 2006, 2:52 pm |
| Need advice on Motel Wireless Setup | July 30, 2006, 11:30 pm |
| need advice on a wifi setup, with a repeater in between.. | August 9, 2006, 9:05 pm |
| Good networking guide?? Advice on Setup?? | December 24, 2004, 6:26 am |
| Advice needed on connecting my neighbour to my wireless setup. | March 3, 2005, 12:53 pm |
| WDS & encryption | January 3, 2006, 2:40 pm |
| Encryption? | January 18, 2006, 2:55 pm |
| Encryption & Authentication | March 20, 2005, 8:45 pm |
| Encryption incompatibility | July 11, 2005, 7:22 pm |
| Questions re WEP encryption | June 27, 2006, 11:16 pm |
| Re: wireless encryption | October 29, 2006, 11:42 am |
| Has 128-bit SSL encryption ever been broken? | December 7, 2006, 4:57 pm |
| WPA encryption problems | November 7, 2007, 5:53 pm |
| does encryption cause intermittent connection? | December 3, 2004, 9:44 pm |
| encryption gives bogus IP addy | January 1, 2005, 5:29 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> broadband
> ISP
> offer
> appreciated! Lisa
