Wireless Networking Laptop wireless
Subject Author Date
Laptop wireless Sue Miller 03-20-08
|--> Re: Laptop wireless Jeff Liebermann03-21-08
Posted by Sue Miller on March 20, 2008, 4:36 am
I'm interested in finding an (online) guide to installing (or
replacing) the full antenna for an internal wireless setup in a
laptop.
My laptop is set up for wireless, but, I stripped the head off the
connector wire (by accident). I can find online guides on how to
replace the card, but, I need information on how to replace the
antenna (or connector wire)
Sue
Posted by gray-beard on March 20, 2008, 9:09 am
> laptop.
> Sue
Go here join the discissions for your laptop brand
And ask away.
http://www.notebookreview.com/
They are normally pretty helpfull
GB
"There's no way to rule innocent men. The only power any government
has is the power to crack down on criminals. Well, when there aren't
enough criminals, one makes them. One declares so many things to be a
crime that it becomes impossible to live without breaking laws."
-- Ayn Rand, Atlas Shrugged
Posted by Jeff Liebermann on March 21, 2008, 7:48 pm
On Thu, 20 Mar 2008 04:36:57 -0400, Sue Miller
>laptop.
>Sue
Any particular maker and model number laptop?
Any particular maker and model number wireless card?
What were you doing that inspired you to destroy the antenna coax
cable? What were you trying to accomplish (besides destroy the
laptop)?
There are usually two coax cables and connectors going to the wireless
card in most laptops. If you trashed one, you can still function on
just the other if it were plugged into the "MAIN" port (instead of the
"AUX" port). If you destroyed both connectors, there are replacement
antennas with cables available for most model laptops. It's almost
impossible to replace just the u-FL connector end.
This might also give you some ideas:
<http://repair4laptop.org/wireless_lan_antennae.html>
The most difficult part is disassembling the laptop and LCD section.
If you've never done this before, be prepared for a major project. If
you have a digital camera, take LOTS of pictures so you can
re-assemble the laptop.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831-336-2558 jeffl@comix.santa-cruz.ca.us
# http://802.11junk.com jeffl@cruzio.com
# http://www.LearnByDestroying.com AE6KS
Posted by P.Schuman on March 28, 2008, 12:53 pm
> laptop.
> Sue
The normal setup is for 1 or 2 tiny coax cables to terminate under the
laptop
where a mini-pci wireless card is installed.
The two tiny coax connectors are then pushed onto the two tiny coax sockets.
http://img76.imageshack.us/img76/6222/dscn09431az.jpg
So - how did you destroy these tiny cable connectors ?
Trying to fix them is like performing blood vessel surgery.
Similar ThreadsPosted
Unable to access wireless network from a laptop / Can from other PC and laptop October 10, 2006, 9:04 pm
Connect a Laptop via Wifi and a VoiP to Laptop via RJ45 September 11, 2007, 10:28 am
Wlan works on 1 laptop, but not anymore on another laptop October 3, 2007, 6:11 pm
wireless laptop-tv is it possible November 2, 2006, 6:54 am
wireless laptop February 7, 2007, 1:26 am
Laptop wireless March 20, 2008, 4:36 am
Intel Pro Wireless PCMCIA Laptop Wireless 802.11a card For Sale - ends in under 24hrs January 21, 2006, 5:03 pm
HP laptop wireless to Desktop PC December 9, 2004, 10:04 pm
sometimes no DNS on wireless laptop from USR8054 January 1, 2005, 4:27 pm
Configuring a wireless laptop August 24, 2005, 5:46 pm
Laptop wireless problems August 27, 2005, 12:09 am
2 Wireless Cards on one laptop October 19, 2005, 4:27 am
Wireless USB wihout PC/laptop November 20, 2005, 1:07 pm
How to connect a wireless laptop? February 19, 2006, 2:26 pm
Which wireless card for Ibm 380 ed laptop April 2, 2006, 1:14 am
