Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by jcgc50 on October 7, 2005, 5:43 pm
Please log in for more thread options Using a Linksys WRT54G router with a broadcom card. Hooked up to a cable modem. Connected directly to the cable modem I get download speeds up to 4mbps. With the router I get half that speed. Is it possible to use wireless and get the full speed benefit of this cable modem? | |||||||||||||||||||||||||||||||
Posted by David Taylor on October 7, 2005, 11:02 pm
Please log in for more thread options What OS? What wireless NIC *exactly*? What encryption? What PC spec? | |||||||||||||||||||||||||||||||
Posted by David Taylor on October 8, 2005, 8:04 am
Pulled out of email reply... >> Using a Linksys WRT54G router with a broadcom card. Hooked up to a
cable
>> modem.
4mbps.
>> >> Connected directly to the cable modem I get download speeds up to >> With the router I get half that speed.
> What OS? > What wireless NIC *exactly*? > What encryption? > What PC spec? > >XP
>802.11 b/g >WPA-PSK >PC spec? what do you mean There are a number of variables at work here and still without the information it's hard to answer. I'll assume from "802.11 b/g" that you means that's the card speed? I know the router is a g but you haven't said what card you have *exactly*. What rate is that connecting at? Just because it's a g card to a g router doesn't mean that the signalling rate is always going to be 54Mbps regardless of how far away you are. One of my machines here has a g card and is presently connected at 2Mbps due to where it is. If you're PC spec is so utterly low that it just can't do encryption to save its life then that will have a factor but you haven't said what spec it is. So first things first, check that the PC is connected at highest speed first, if things are still slow, then turn off encryption and see what throughput you get. David. | |||||||||||||||||||||||||||||||
Posted by Derek Broughton on October 8, 2005, 12:56 pm
David Taylor wrote: > Pulled out of email reply...
> cable
>>> modem.
>>> >>> Connected directly to the cable modem I get download speeds up to > 4mbps.
>> What OS? >> What wireless NIC *exactly*? >> What encryption? >> What PC spec? >>PC spec? what do you mean
> If you're PC spec is so utterly low that it just can't do encryption to > save its life then that will have a factor but you haven't said what > spec it is. And you haven't answered his question about what you mean by "PC spec". I'd guess you want to know type of processor and speed, but it's a new one on me, too. -- derek | |||||||||||||||||||||||||||||||
Posted by David Taylor on October 8, 2005, 9:36 pm
> guess you want to know type of processor and speed, but it's a new one on > me, too. Had I put a . at the end of spec. would that have made it clearer?! :) PC Spec. as in abbreviation for "specification" | |||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Is there a way to increase speed | October 7, 2005, 5:43 pm |
| Wired speed: excellent -- Wireless speed: like an 80s modem (tops). | October 7, 2006, 6:05 pm |
| Together we can increase your sales | August 18, 2006, 1:02 am |
| Increase range of Wi-Fi | March 11, 2007, 1:58 pm |
| Re: How to Increase Your Wi-Fi Signal | August 9, 2007, 1:31 pm |
| Increase range of DLink DI-524 | January 16, 2006, 12:43 pm |
| Wireless signal increase... | July 27, 2007, 10:06 am |
| Anyone using two Transceivers to increase throughput? | June 26, 2008, 4:21 am |
| increase the number of port ranges? | January 10, 2006, 7:55 pm |
| DWL-2100ap Firmware to increase power | January 8, 2007, 5:35 pm |
| Increase a laptop wifi range | September 17, 2007, 8:35 pm |
| Any inexpensive ways to increase range indoors ? | October 20, 2005, 11:49 pm |
| "Cantennas" to increase wifi transmitter range | November 26, 2005, 10:44 pm |
| 2.4Ghz ampliier increase signal strength? | December 30, 2005, 11:33 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> modem.
