Wireless Networking IE6 won't use wireless card [was XP wireless not working]
Subject Author Date
IE6 won't use wireless card [was XP wireless not working] George Neuner 05-12-08
Posted by seaweedsl on May 14, 2008, 10:29 am
> Have checked your proxy settings?
> Other options on the Connections tab?
> Note that all wi-fi connections go under the "LAN" category in Connections.
Yes, this is the obvious thing to check first; in IE6 go to
tools>Internet options >Connections>LAN and make sure proxy is off and
it detects the network automatically.
Posted by Jeff Liebermann on May 15, 2008, 11:48 am
On Mon, 12 May 2008 22:34:31 -0400, George Neuner
>IE6 refuses to work with the card unless my office VPN is
>active. I tried asking in IE6 specific forums, but after a few days
>I've gotten no useful answers so I thought I'd try here.
The reason you need the VPN is that your default gateway is probably
pointing to the gateway IP on the office router. That's NOT the
correct way to setup a VPN on a mobile device. However, you may be in
luck if only IE6 is NOT working.
Start IE6 and go unto:
Tools -> Internet Options -> Connections
My first guess(tm) is that you have it set to always dial the VPN
connection or some kind of profile that points to the old wireless
card. Try it with "Never dial a connection" and see if that fixes
IE6.
If not, my 2nd guess(tm) is to select "Lan Settings" on that page,
record the current settings so you can put them back if necessary, and
clear out whatever is in the "Proxy Server" settings. Also, make sure
that "Automatically Detect Settings is *NOT* checked.
I dunno if these guesses will help, but it's worth trying. Otherwise,
I suggest you have your company IT people set it up exactly the way
you want it.
Jeff Liebermann jeffl@cruzio.com
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Similar ThreadsPosted
Belkin Wireless G desktop card - not working January 31, 2006, 4:16 pm
How can I tell whether a ASUS Wireless PCI Card WL-138GE is working? September 27, 2007, 9:27 am
IE6 won't use wireless card [was XP wireless not working] May 12, 2008, 10:34 pm
Notebook Mini PCI card not working June 5, 2005, 8:36 pm
Demarc 300mw wifi card not working May 17, 2006, 1:57 pm
WPA on Quickertek(Ralink) card on Mac Powerbook not working April 6, 2008, 5:56 pm
wireless isn't working!! January 31, 2006, 11:20 am
Wireless not working February 3, 2006, 5:12 am
g3 wireless ics not working November 14, 2006, 4:13 pm
Wireless working on one PC but not on another November 11, 2007, 4:35 pm
Wireless not working November 19, 2007, 6:25 am
Help! XP wireless not working May 4, 2008, 3:43 pm
Wireless not working with certain sites November 29, 2005, 5:06 pm
Wireless adapter not working December 28, 2006, 12:17 pm
Wireless network not working January 27, 2007, 1:42 pm
