Wireless Networking IE6 won't use wireless card [was XP wireless not working]
Subject Author Date
IE6 won't use wireless card [was XP wireless not working] George Neuner 05-12-08
Posted by George Neuner on May 12, 2008, 10:34 pm
Thanks to everyone who responded to the last thread. I finally
discovered that the Netgear Super-G card was intermittently failing
and probably just happened to work when I tried it in another
computer.
I replaced the failing card with a new one, but now I have a new
problem. IE6 refuses to work with the card unless my office VPN is
active. I tried asking in IE6 specific forums, but after a few days
I've gotten no useful answers so I thought I'd try here.
The situation is this: my office laptop has built-in 11b radio, but at
home I have a Netgear Super-G network so I use a WG511T card instead.
The laptop also has a Cisco VPN set up by office IT. Normally, I
should be able to use either radio, use my own network with the VPN
disabled (and IE proxy settings disabled) and then connect the VPN to
use my office network. This is the way I used my old Netgear card and
it still works the same with the built-in 11b radio.
However, with the new Netgear card, IE6 won't work unless the VPN is
connected. When the VPN is disabled, all I get is "can't display page
- can't find server or DNS error" regardless of proxy settings. I get
the same error even if I type the server's address manually so it
seems like IE6 isn't even trying.
Other net apps (Outlook, ftp, ping, trace, nslookup) are working
normally regardless of the VPN - when VPN is connected they route
through my office, otherwise they route through my home network and
ISP. Only IE6 demands the VPN be active.
I can't find any settings different between the connection using the
new card and the one using the built-in radio - both are configured
through DHCP from my router and the settings all appear to be correct.
Naturally the routing tables all change when the VPN is active. All
the IE6 settings appear to be the same regardless of connection. I've
tried uninstalling/reinstalling the Netgear card, flushing the DNS and
browser caches when the card is in use, enabling/disabling the IE6
proxy settings, etc. Nothing has worked. IE6 seems to be completely
ignoring the proxy settings and just expecting the VPN all the time.
There don't seem to be any settings for specific connections or
devices in the Cisco VPN - it seems to just take over everything when
it's active.
I don't have any way of reinstalling IE6 (or anything else). Is there
something I can check in the registry or in some setup file(s)? Any
other thoughts or suggestions? At this point I'm completely baffled.
George
for email reply remove "/" from address
Posted by smlunatick on May 13, 2008, 9:16 am
> Thanks to everyone who responded to the last thread. =A0I finally
> computer.
> problem. =A0IE6 refuses to work with the card unless my office VPN is
> active. =A0I tried asking in IE6 specific forums, but after a few days
> The laptop also has a Cisco VPN set up by office IT. =A0Normally, I
> use my office network. =A0This is the way I used my old Netgear card and
> connected. =A0When the VPN is disabled, all I get is "can't display page
> - can't find server or DNS error" regardless of proxy settings. =A0I get
> ISP. =A0Only IE6 demands the VPN be active.
> Naturally the routing tables all change when the VPN is active. =A0All
> the IE6 settings appear to be the same regardless of connection. =A0I've
> proxy settings, etc. =A0Nothing has worked. =A0IE6 seems to be completely
> it's active.
> I don't have any way of reinstalling IE6 (or anything else). =A0Is there
> something I can check in the registry or in some setup file(s)? =A0Any
> other thoughts or suggestions? =A0At this point I'm completely baffled.
> George
It sounds like your laptop is configured to only use the Internet
service that your "office" is set up for. Check the DNS servers
settings, whoich might be entered in the Network Connections
Posted by George Neuner on May 13, 2008, 12:32 pm
On Tue, 13 May 2008 06:16:33 -0700 (PDT), smlunatick
Thanks for responding. I've checked DNS settings - all connections
are configured through DHCP. The VPN takes over all routing when
enabled, but when it's disabled the connection settings are correct
for my home router.
What's confusing me is that everything worked as expected with the old
Netgear Super-G card ... but now that I have a new card, IE alone
refuses to use it while all my other network apps work as before. And
everything, including IE, works as before using the internal 11b
radio. I can't figure out why there is a difference with the new
hardware.
George
Posted by smlunatick on May 13, 2008, 2:13 pm
> >service that your "office" is set up for. =A0Check the DNS servers
> Hi,
> Thanks for responding. =A0I've checked DNS settings - all connections
> are configured through DHCP. =A0The VPN takes over all routing when
> for my home router.
> refuses to use it while all my other network apps work as before. =A0And
> radio. =A0I can't figure out why there is a difference with the new
> hardware.
> George
Have you consider trying to use your "old" 11b adapter, as a test?
Did you "uninstall" the odle Netgear drivers from the PC?
Posted by George Neuner on May 13, 2008, 4:17 pm
On Tue, 13 May 2008 11:13:21 -0700 (PDT), smlunatick
>> Hi,
>> for my home router.
>> hardware.
>> George
All applications work with the built-in 11b radio. They all worked
with the old (now broken) Netgear Super-G card as well. Everything
*except* IE6 works with the new Netgear Super-G card.
>Did you "uninstall" the old Netgear drivers from the PC?
Yes. The new card is a different model so I had to uninstall the old
drivers and install the new. I ran Registry Mechanic afterward to
clean up anything the uninstall missed.
Honestly, IE6 is the only network application that won't work properly
with the new card. I am completely baffled.
George
Similar ThreadsPosted
Belkin Wireless G desktop card - not working January 31, 2006, 4:16 pm
How can I tell whether a ASUS Wireless PCI Card WL-138GE is working? September 27, 2007, 9:27 am
IE6 won't use wireless card [was XP wireless not working] May 12, 2008, 10:34 pm
Notebook Mini PCI card not working June 5, 2005, 8:36 pm
Demarc 300mw wifi card not working May 17, 2006, 1:57 pm
WPA on Quickertek(Ralink) card on Mac Powerbook not working April 6, 2008, 5:56 pm
wireless isn't working!! January 31, 2006, 11:20 am
Wireless not working February 3, 2006, 5:12 am
g3 wireless ics not working November 14, 2006, 4:13 pm
Wireless working on one PC but not on another November 11, 2007, 4:35 pm
Wireless not working November 19, 2007, 6:25 am
Help! XP wireless not working May 4, 2008, 3:43 pm
Wireless not working with certain sites November 29, 2005, 5:06 pm
Wireless adapter not working December 28, 2006, 12:17 pm
Wireless network not working January 27, 2007, 1:42 pm
