Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Dave on July 13, 2008, 3:00 pm
Please log in for more thread options using ICS from the PCI broadband card to the ethernet port. I then used a router as an A/P only. The laptop is underpowered and performance was lousy. I am wondering if I can use bridging to pass the broadband signal directly to the ethernet and then use the router as a true router? I tried it once quickly and it appeared to not work. Anyone have knowlege of such bridging? Thanks, Dave | ||||||||||||||||||||||||||||
Posted by DanS on July 13, 2008, 9:09 pm
Please log in for more thread options IS there a reason you don't want the rtr first ? | ||||||||||||||||||||||||||||
Posted by Dave on July 13, 2008, 11:53 pm
Please log in for more thread options wrote:
> f488a3557...@m45g2000hsb.googlegroups.com:
> > > This spring I shared a broadband connection from a laptop in Mexico by
> > using ICS from the PCI broadband card to the ethernet port. I then > > used a router as an A/P only. The laptop is underpowered and > > performance was lousy. >
> > directly to the ethernet and then use the router as a true router? I > > tried it once quickly and it appeared to not work. Anyone have > > knowlege of such bridging? >
> > Thanks, Dave
> IS there a reason you don't want the rtr first ? I want the router to handle routing and DHCP not ICS on the laptop. Dave | ||||||||||||||||||||||||||||
Posted by Bill Kearney on July 14, 2008, 9:51 am
Please log in for more thread options > I am wondering if I can use bridging to pass the broadband signal
What signal is this? Where is it coming from? From a wired connection or wireless? The term "broadband" usually means WIRED, not wireless. > directly to the ethernet and then use the router as a true router? I
> tried it once quickly and it appeared to not work. Anyone have > knowlege of such bridging? ICS is often more trouble than it's worth. It requires setting up a specific IP address on the machine doing the sharing. This is fine if you're just sharing one connection, but with multiples it gets to be an adventure. What connection is being used to get to the internet? | ||||||||||||||||||||||||||||
Posted by Dave on July 14, 2008, 10:02 am
Please log in for more thread options > > I am wondering if I can use bridging to pass the broadband signal
> What signal is this? Where is it coming from? From a wired connection or > wireless? The term "broadband" usually means WIRED, not wireless. > > > directly to the ethernet and then use the router as a true router? I
> ICS is often more trouble than it's worth. It requires setting up a > specific IP address on the machine doing the sharing. This is fine if > you're just sharing one connection, but with multiples it gets to be an > adventure. > > What connection is being used to get to the internet? The broadband connection is from Telcel via a PCI broadband wireless card. I just want to pass this connection seamlessly thru the laptop to the broadband ethernet port of a router. That's the question. I don't have a remotely similar lashup here at home to experiment with. I'll be going bach to Mexico in a few months and would like to have a plan for better sharing. Dave | ||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Bridging | November 28, 2005, 8:11 pm |
| Bridging | September 3, 2006, 9:48 pm |
| ICS or Bridging? | July 13, 2008, 3:00 pm |
| Bridging question | November 7, 2005, 6:34 pm |
| Wireless bridging | November 14, 2005, 9:28 am |
| 802.11g/n bridging routers? | May 1, 2006, 1:06 pm |
| Wireless Bridging / WDS | January 24, 2007, 12:14 pm |
| WG802v2 bridging problem | December 1, 2004, 9:33 am |
| Bridging wrt54g to wgt624 | December 12, 2004, 6:54 pm |
| Linksys WRT54G & ?Bridging? | February 6, 2005, 8:16 pm |
| Bridging D-Link Wireless | August 9, 2005, 6:41 pm |
| Bridging with SWEEX LC000070? | September 29, 2005, 4:45 pm |
| Info on Wireless bridging... | October 5, 2005, 3:54 am |
| What evices to use for Trasparent bridging ? | March 9, 2007, 11:53 am |
| Wireless Bridging Without a Bridge | August 30, 2007, 11:32 am |
ICS or Bridging?
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Thanks, Dave
