Wireless Networking HELP: specific 2.4GHz video xmitter interference, what causes it?
Subject Author Date
HELP: specific 2.4GHz video xmitter interference, what causes it? mw210461@gmail.com 07-11-08
Posted by mw210461@gmail.com on July 11, 2008, 3:19 pm
I am going nuts.
We are using a 2.4GHz wireless video broadcaster in our home (Germany,
240V, 50Hz, PAL TV 25fps). It is based in the lower level and
transmits a satellite receiver output to the upper level TV room,
about 25ft away (3x 1ft stone walls in between).
The received video signal has a large regular interference, a
horizonal stripe (about 5% high, small vertical bands with colored
specks, almost white appearance) crawls fast through the picture,
accompanied by a chopping noise, about 8-10 chops per second. The
stripe scrolls fast through the picture, about 2-3 times per second,
downwards.
A classical interference. PAL operates at 25cycles per second, German
power at 50Hz, what does this tell about the interference spectrum/
freq?
Yes, we have a variety of other wireless devices in the house,
including a Fritz! WLAN, 2 2.4GHz phone bases (5 mobile phones),
several wireless weather stations, a Razr cell phone.
I pulled ALL plugs of all known wireless devices, unscrewed fuses
wherever needed, NADA! The noise remains, as strong as before.
I even put all wireless phones into a metal box and carried it out of
the building, still no change.
Meaning that all my wireless devices do NOT have any impact at all,
the other noise is the main problem. WHERE THE HELL IS IT COMING FROM?
The received video signal is rather weak, moving the receiver around
yields interesting spots of "almost" no noise (about 1ft apart).
Interesting to note: the noise gets typically more solid if the
overall picture is better and clear/strong. Meaning if I settle for a
grainy video, then the stripe is almost invisible (yet noticable in
the audio part as the mentioned fast 'chop chop chop' noise)
I am at the end of my wits. Cannot analyze freq sprectrum nor do I
have other tools handy to investigate. Am a left handed physicist, not
an electrical freak, hence my plead for support here!
What could cause this strong interference, a neighbor, the power line,
the antenna from the satellite/cable (even switched off the HF
amplifier for TV)?
What else should I try to isolate the problem? Cut the power line of
all my neighbors?
Thanks a bunch!
michael
Posted by DanS on July 11, 2008, 6:06 pm
af24-2190158ed5a6@34g2000hsh.googlegroups.com:
> I am going nuts.
<SNIP>
> amplifier for TV)?
> all my neighbors?
> Thanks a bunch!
> michael
Had you ever seen this device work properly anywhere, the one you own ?
Maybe the device is defective.
Posted by mw210461@gmail.com on July 12, 2008, 3:56 am
wrote:
0-
> af24-2190158ed...@34g2000hsh.googlegroups.com:
> > I am going nuts.
> > We are using a2.4GHzwireless video broadcaster in our home (Germany,
> <SNIP>
> > the antenna from =A0the satellite/cable (even switched off the HF
> > amplifier for TV)?
> > all my neighbors?
> > Thanks a bunch!
> > michael
I am pretty sure I did test it with good results (before we moved),
but cannot say for sure.
Since none of my own devices is causing it I still asume an external
noise source, mainly the neighbor's strong WLAN (I can sensek his
signal with my own PCs while I can hardly get my own ethernet signals
down to the basement).
Would need a Faraday cage to test the entire xmitter system in, but
don't have any setup to do so.
The xmiiter has 4 channels to operate at, all of them show the same
interference.
Posted by Joker7 on July 12, 2008, 6:00 am
To restore balance to the world mw210461@gmail.com wrote in
7d76831c-f322-4ff0-af24-2190158ed5a6@34g2000hsh.googlegroups.com
>> I am going nuts.
>> (Germany, 240V, 50Hz, PAL TV 25fps). It is based in the lower level
>> and transmits a satellite receiver output to the upper level TV room,
>> downwards.
>> freq?
>> FROM?
>> not an electrical freak, hence my plead for support here!
>> line, the antenna from the satellite/cable (even switched off the HF
>> amplifier for TV)?
>> all my neighbors?
>> Thanks a bunch!
>> michael
Poor weak signal - do a test move the receiver to the same room as the
transmitter (3ft of stone)...
Chris
Superb hosting & domain name deals http://dn-22.co.uk
The Handyman http://www.looker.me.uk
The FlatPack Man http://www.flat-pack.info
Posted by mw210461@gmail.com on July 13, 2008, 4:44 am
> To restore balance to the world mw210...@gmail.com =A0wrote in
> 7d76831c-f322-4ff0-af24-2190158ed...@34g2000hsh.googlegroups.com
> >> I am going nuts.
> >> downwards.
> >> freq?
> >> including a Fritz! WLAN, 22.4GHzphone bases (5 mobile phones),
> >> I pulled ALL plugs of all known =A0wireless devices, unscrewed fuses
> >> FROM?
> >> line, the antenna from =A0the satellite/cable (even switched off the H=
F
> >> amplifier for TV)?
> >> all my neighbors?
> >> Thanks a bunch!
> >> michael
> transmitter =A0(3ft of stone)...
> Chris
> Superb hosting & domain name dealshttp://dn-22.co.uk
> The Handymanhttp://www.looker.me.uk
> The FlatPack Manhttp://www.flat-pack.info- Zitierten Text ausblenden -
> - Zitierten Text anzeigen -
I do agree that the signal strength is low, mainly caused by the 3
thick walls and floors.
But I DO have success, sort of:
the transmitter allows to select 4 different broadcast channels, and
in one (D, the highest?) I noticed that the wide speckled and running
bar disappeared. It was replaced by 2 very narrow and absolutely
static ones! That was actually good news, as it was a DIFFERENT
interference, one I quickly identified as being from my own wireless
base station, located in the same room as the 2.4GHz receiver. That
one can be unplugged anytime; also I am considering to disable/cut
the
transmitter or antenna - the base is not actively used, it only
serves
as a charger for one cordless phone.
It produces a very sharp, whitish bar, in synch with the receiver for
some reason
(overtone or fraction of the xmit frequency I suppose?), no audio
interference noticable.
I am quite convinced that the other broad noise is indeed from a
neighbor's WiFi/WLAN system. What is baffling is that the plentitude
of my own wireless devices (with the exception of the one phone base
in the same room) have absolutely no impact on the xmitter/receiver
signal, and this bastard HAS, from 100ft away, through several 1foot
mason walls. What is he using??
Anyways - thanks for the ideas, hints and suggestions, highly
appreciated!
michael
Similar ThreadsPosted
HELP: specific 2.4GHz video xmitter interference, what causes it? July 11, 2008, 3:19 pm
Netgear WGR614 router and 2.4Ghz phone interference November 15, 2004, 7:27 pm
How to convert DVD, video, flash to iphone video? July 8, 2007, 3:00 am
specific ip address for ftp? August 4, 2007, 4:22 pm
Specific topology with WRT54GS? December 5, 2004, 12:11 pm
Any reason why a d-link router's firmware upgrade can't be used outside a specific country ? June 14, 2006, 9:33 am
2.4ghz question October 23, 2004, 5:41 pm
FM transceiver @ 2.4GHz September 6, 2006, 10:22 pm
Leaky Coax for 2.4GHz? December 6, 2004, 10:26 am
where to buy 2.4ghz antenna cable May 8, 2006, 1:05 pm
Maxi booster on 2,4GHz May 16, 2006, 8:09 pm
915mHz compatible with 2.4gHz? September 25, 2006, 6:53 pm
Re: 915mHz compatible with 2.4gHz? September 25, 2006, 11:20 pm
Better Antenna for LinkSys USB 2.4Ghz Unit October 27, 2005, 1:56 pm
WTB: 2.4Ghz Replacement Stubby Antenna March 5, 2006, 9:17 am
