Wireless Networking Dynamically Change SSID
Subject Author Date
Dynamically Change SSID fernandez.dan 06-19-08
Posted by on June 19, 2008, 11:27 am
I've looking for information on how to change the SSID dynamically. I
want to use a USB Wirless Adapter on different PCs in Ad Hoc Mode. I
want to be able to change the SSID for USB Wireless Adapter
dynamically based on a configuration. I don't want to use the vendor
setup software, is there a way to set up the USB wirelss Adapter.
I appreciate pointing me to documenation or advice.
Posted by Jeff Liebermann on June 19, 2008, 9:04 pm
On Thu, 19 Jun 2008 08:27:30 -0700 (PDT), fernandez.dan@gmail.com
Are you sure you're not planning a DoS (denial of service) attack?
>I want to use a USB Wirless Adapter on different PCs in Ad Hoc Mode. I
Based on what configuration? Wireless config? Laptop config? Network
config? Device (hardware) config?
Any particular operating system? If you going between different OS's,
you *WILL* have problems.
Documentation? Nobody reads the docs.
The sloppy way is to find the registry key that holds the SSID. It
might be in a config file somewhere depending on hardware, but for
USB, it's mostly like buried in the registry. Use a free registry
search and destroy tool like:
<http://www.resplendence.com/registrar>
as there may be more than one place in the registry where it's buried.
If you want to move the USB device with it's settings, you'll have to
grab the rest of the registry key, especially the MAC address.
After you extract the key, create a collection of .REG files, each
with a different SSID. To change the SSID, just run the .REG file.
The problem with this is that some devices temporarily store the
connection details in the device. If it doesn't work, try just
unplugging the USB dongle, and then plugging it back in.
Another method is to use software specifically designed for the
purpose. I use:
<http://www.netswitcher.com>
I have about 15 profiles setup, one for each of my major customers
networks. If I need to work at one of these customers, I merely run
Netswitcher, which changes all my network and email settings.
Sometimes I have to reboot. Whether it will work for your unspecified
USB devices is unknown. Methinks it will. If not there are other
similar programs that can be used (and I'm too lazy to excavate).
Jeff Liebermann jeffl@cruzio.com
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Similar ThreadsPosted
Dynamically Change SSID June 19, 2008, 11:27 am
How to keep a static IP and let DNS addresses be dynamically updated on Linksys WRT54GS ? August 24, 2005, 9:34 am
non-ssid, changed ssid, wpa on network; what else can i do? December 17, 2005, 11:58 am
change MAC address can change IP address of a machine? September 30, 2005, 10:25 am
i can't see my ssid... April 6, 2006, 2:52 pm
Can't see SSID June 19, 2007, 9:40 pm
SSID December 6, 2007, 4:40 pm
Can I and why would I have a DIFFERENT SSID for my 2nd WAP April 26, 2008, 5:16 pm
Wireless SSID October 18, 2004, 10:28 pm
ad-hoc SSID broadcasting November 14, 2004, 12:42 am
info on SSID November 15, 2004, 10:06 pm
Broadcasting SSID December 11, 2004, 10:26 pm
Do I Have To Broadcast my SSID? December 30, 2004, 11:21 am
VLAN & SSID March 8, 2005, 3:44 am
SSID format? May 25, 2005, 1:56 am
