Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by J David Ellis on January 26, 2006, 5:26 am
Please log in for more thread options After reading horror stories on groups about most wireless print servers being incompatible with the printer, failing to provide claimed WPA capability and manufacturer refusal to publish a compatibility list, I'm wondering if any manufacturer provides a server that works? I want one for a Laserjet 1100 and one for a Canon S800. Can you recommend a wireless print server that delivers what the hype promises? --David | |||||||||||||||||||
Posted by Rosco on January 26, 2006, 10:53 am
Please log in for more thread options J David Ellis cried out for the HP, visit HP's website and look at the differnt models of the JetDirect... | |||||||||||||||||||
Posted by J David Ellis on January 26, 2006, 1:39 pm
Rosco wrote: > J David Ellis cried out
>>print servers being incompatible with the printer, failing >>to provide claimed WPA capability and manufacturer refusal >>to publish a compatibility list, I'm wondering if any >>manufacturer provides a server that works? >> >>I want one for a Laserjet 1100 and one for a Canon S800. >> >>Can you recommend a wireless print server that delivers what >>the hype promises? >> >>--David >> >
> > for the HP, visit HP's website and look at the differnt models of the > JetDirect... Thanks for the pointer. At hp.com there's an "HP Jetdirect ew2400 802.11g Wireless Print Server" that lacks a parallel port for my Laserjet 1100. What are the chances the ew2400/LJ1100 would work with a parallel-to-USB2 cable? | |||||||||||||||||||
Posted by Jeff Liebermann on January 26, 2006, 12:59 pm
>print servers being incompatible with the printer, failing >to provide claimed WPA capability and manufacturer refusal >to publish a compatibility list, I'm wondering if any >manufacturer provides a server that works? > >I want one for a Laserjet 1100 and one for a Canon S800. > >Can you recommend a wireless print server that delivers what >the hype promises? The HP LaserJet 1100 has both USB and parallel ports. While USB is easier to cable, it had driver "issues" which you've apparently experienced. My luck with USB print servers has been dismal. Most of the slightly older parallel port print servers will work. Make sure that it had bi-directional support (IEEE-1284) on the parallel port interface or the Windoze will not get proper status information. I have a customer with an office full of HP1100, 1200, and 1300 printers that uses a mix of Netgear PS104, PS110, HP300x, and other print servers. However, these are not wireless. There is one printer (not sure of model), on a roll around cart, that uses a Dlink wireless print server. I think it's one of these: http://www.dlink.com/products/?sec=0&pid=174 http://www.dlink.com/products/?pid=461&sec=0 but I'm not sure which. Your Canon S800 is about 5 years old and also has a parallel port. The same advice as before. Use the parallel port and make sure the print server does IEEE-1284. If you insist on USB, you might calculate the cost of the print server (about $75) against the cost of a new printer with built in wireless. -- Jeff Liebermann jeffl@comix.santa-cruz.ca.us 150 Felker St #D http://www.LearnByDestroying.com Santa Cruz CA 95060 http://802.11junk.com Skype: JeffLiebermann AE6KS 831-336-2558 | |||||||||||||||||||
Posted by Bob II on January 26, 2006, 1:30 pm
Jeff Liebermann wrote: >
> > The HP LaserJet 1100 has both USB and parallel ports. While USB is > easier to cable, it had driver "issues" which you've apparently > experienced. My luck with USB print servers has been dismal. > > Most of the slightly older parallel port print servers will work. Make > sure that it had bi-directional support (IEEE-1284) on the parallel > port interface or the Windoze will not get proper status information. > I have a customer with an office full of HP1100, 1200, and 1300 > printers that uses a mix of Netgear PS104, PS110, HP300x, and other > print servers. However, these are not wireless. There is one printer > (not sure of model), on a roll around cart, that uses a Dlink wireless > print server. I think it's one of these: > http://www.dlink.com/products/?sec=0&pid=174 > http://www.dlink.com/products/?pid=461&sec=0 > but I'm not sure which. There is also http://www.dlink.com/products/?pid=336&sec=0 Although I could only see wpa-psk in Uk f/ware(odd!) Compatibility list Long:- http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321 Short:- http://tinyurl.com/axfld Laserjet 1100 is mentioned but not the S800 They also have the usual warning about only the print function working on multi-function printers. >
> Your Canon S800 is about 5 years old and also has a parallel port. The > same advice as before. Use the parallel port and make sure the print > server does IEEE-1284. If you insist on USB, you might calculate the > cost of the print server (about $75) against the cost of a new printer > with built in wireless. > | |||||||||||||||||||
| Similar Threads | Posted |
| Can a router w/ print server work as a plain print server? | November 2, 2004, 9:22 pm |
| Does any wireless print server work? | January 26, 2006, 5:26 am |
| Problems with US Robotics 5461 wireless print server - "cant create print job" | December 9, 2006, 1:40 pm |
| Print Server vs Print / Scan Server | November 13, 2004, 6:38 pm |
| wireless print server | April 25, 2005, 11:17 pm |
| Wireless Print Server Help | September 13, 2005, 6:00 pm |
| Wireless Print server | November 1, 2007, 7:56 pm |
| wireless "b" print server on G network | November 23, 2005, 4:46 pm |
| wireless print server two-sided | November 30, 2005, 9:59 am |
| Belkin Wireless Print Server | April 12, 2006, 2:41 am |
| Wireless print server question. | May 25, 2006, 5:17 pm |
| Wireless print server problems | May 25, 2006, 5:26 pm |
| Wireless print server question | August 4, 2007, 4:27 pm |
| Wireless print server (Centronics) recommendation | August 13, 2005, 6:56 am |
| Wireless print server with parallel port & WPA | September 5, 2005, 1:47 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> the hype promises?
> --David
