Wireless Networking Does WPA and WPA2 wireless encryption work on Vista?
Subject Author Date
Does WPA and WPA2 wireless encryption work on Vista? void.no.spam.com@gmail.com 07-13-08
Posted by void.no.spam.com@gmail.com on July 13, 2008, 3:54 pm
I have Vista Home Premium with SP1 and all the updates installed. I
have a MSI PC60G wireless adapter, with the latest driver, and it is
unable to connect to my Linksys WRT54GL router with WPA or WPA2. I
know that the router is working fine, because I can use an XP laptop
to connect to the router using WPA or WPA2. But with the Vista
machine, it always shows a "The wireless network security key is not
correct" when I use the diagnose option to see why it doesn't connect
using WPA/AES or WPA/TKIP or WPA2/AES or WPA2/TKIP. Vista can tell
that the network is there, as it shows the network name with 5 green
bars in the wireless connection window. It can also tell when I have
changed the security settings on the router, as it will say "The
settings saved on this computer for the network do not match the
requirements of the network." But it just won't connect to the router
using WPA or WPA2 for some reason. If I configure the router with
WEP, then Vista connects fine, but I want to use WPA or WPA2.
Can someone please confirm that wireless connections using WPA and
WPA2 are working in Vista? If so, then it must be a problem with the
PC60G wireless adapter. The PC60G uses a Ralink RT2561 chip, and I
have the latest driver installed for that. I even tried the latest
MSI driver, which is older than the latest Ralink driver, and that
still did not work. MSI says that the PC60G supports both Vista and
WPA2, but something is not working here.
Posted by Pen on July 13, 2008, 4:18 pm
I had a laptop working fine using Vista Business with WPA2 Personal and
TKIP+AES. I blew off Vista to go back to XP for various other reasons.
Posted by Larry Finger on July 13, 2008, 4:53 pm
We use WPA-PSK/TKIP with XP, Vista and Linux.
Posted by LR on July 13, 2008, 4:57 pm
I also have a Vista Home Premium SP1 machine which has an AR5007
wireless card and have no problems with WPA2-PSK/AES encryption.
Have you tried rolling back to pre-SP1 to see if it works and if it is
the SP1 upgrade that is the problem as both sets of drivers are pre-SP1.
Posted by smlunatick on July 14, 2008, 11:24 am
On Jul 13, 8:54=A0pm, "void.no.spam....@gmail.com"
> I have Vista Home Premium with SP1 and all the updates installed. =A0I
> unable to connect to my Linksys WRT54GL router with WPA or WPA2. =A0I
> to connect to the router using WPA or WPA2. =A0But with the Vista
> using WPA/AES or WPA/TKIP or WPA2/AES or WPA2/TKIP. =A0Vista can tell
> bars in the wireless connection window. =A0It can also tell when I have
> requirements of the network." =A0But it just won't connect to the router
> using WPA or WPA2 for some reason. =A0If I configure the router with
> WPA2 are working in Vista? =A0If so, then it must be a problem with the
> PC60G wireless adapter. =A0The PC60G uses a Ralink RT2561 chip, and I
> have the latest driver installed for that. =A0I even tried the latest
> still did not work. =A0MSI says that the PC60G supports both Vista and
What firewall software, if any, are you using on this Vista PC? I've
encountered a firewall software that blocks wireless SSIDs if not told
to trust it.
Similar ThreadsPosted
Does WPA and WPA2 wireless encryption work on Vista? July 13, 2008, 3:54 pm
Does Orinoco Gold card work with Vista? April 28, 2008, 6:24 pm
WPC300N linksys vista drivers not accepted in Vista September 4, 2007, 11:20 pm
Need wireless bridge recommendations w/ wpa2 March 21, 2008, 6:57 pm
Radiuz (WPA/WPA2 Enterprise for home and SOHO wireless) August 7, 2006, 12:16 pm
vista wireless laptop and wii January 13, 2008, 4:39 pm
Re: wireless encryption October 29, 2006, 11:42 am
vista & atheros wireless chipset with WPA July 9, 2007, 7:19 pm
Vista- Connecting to wireless network. August 28, 2007, 9:21 am
vista doesn't autoconnect to wireless after startup October 16, 2007, 4:55 pm
Using Vista + Wireless on same machine with the router? November 14, 2007, 9:21 pm
Vista Wireless-N Slow to a Crawl Please Help.... May 6, 2008, 11:54 am
Wireless encryption (Linksys)? July 30, 2005, 5:20 pm
Vista Linksys USB11 b wireless adapter ?? March 18, 2007, 11:01 pm
Do any wireless pci cards have 64bit vista drivers? June 2, 2007, 1:46 am
