Wireless Networking Do I need a new wireless router
Subject Author Date
Do I need a new wireless router Les 06-19-08
Posted by Les on June 19, 2008, 7:50 pm
Currently have a Linksys router WRK54G that I bought 3 yrs ago. I have
created a home network, consisting of 2 different wireless laptops and a
wireless printer. I have an internet cable modem connected to the router
and the network works just fine.
In the future, my large community will have wireless internet connectivity,
so I will no longer need the internet cable service, which I will cancel.
The company that manages the community wireless internet connnectivity will
get each computers MAC address so each can access their network to get on
the internet.
My objective is to have each computer able to print to the wireless printer,
as well on get on the internet. I have been told I will need to purchase a
wireless router, to take the place of my current router. Is this true? If
so, why is that necessary?
Posted by Jeff Liebermann on June 19, 2008, 8:54 pm
On Thu, 19 Jun 2008 19:50:06 -0400, "Les"
>the internet.
Why would you want to abandon your cable modem internet for a wireless
equivalent? Has the pitch line included any alleged benefits? I
assure you that speed and reliability of wireless will be much less.
If you're going for the wireless solution, you have two choices. You
can buy a new wired router, since the WAN port of your unspecified
model cable router is probably inaccessible and therefore cannot be
used. In addition to the new router, you also might need a new
"wireless client ethernet bridge" which may or may not be supplied by
the wireless ISP.
The other option is to connect directly to the wireless network using
the two laptops and wireless printer. If the ISP has client isolation
enabled (highly likely), you will NOT be able to transfer files
between laptops and printers.
Methinks you had better talk to the wireless ISP to see what they
recommend.
Jeff Liebermann jeffl@cruzio.com
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Posted by test on June 20, 2008, 11:45 am
>the internet.
Hi
I tend to agree with Jeff's sentiments on wired vs. wireless. If you
choose to go the wireless route - I had to set something up similar as
a fix while being on-site for a client in LA. The place I was staying
only had wireless access points but I had multiple systems and VOIP to
get functioning. My hack was to use cheap Buffalo router (WHR-G125)
and upgrade the firmware to that of DD-WRT. Using it you can setup
the router to act as both a router and a bridge so it will receive
signals from the AP but also act as a router for all your devices.
Take a look at http://www.dd-wrt.com/wiki/index.php/Repeater_Bridge
My main hitch was that I had to relogon the on-site AP every day b/c
their DHCP leases renews at 2AM every AM and I could not get DD-WRT to
renew automatically (it has some provisions for it). It was not great
but it functioned and I ran VOIP, Cisco VPN's through it without
issues.
Hope this helps
Jerry Henzel
Precipice Development Intl
precipice.development can be contacted at gmail.com
http://www.precipicedevelopment.com
Posted by seaweedsl on June 20, 2008, 12:17 pm
Stick with cable and forget the new system. You already have a
superior setup.
There are some ASUS G routers for a good price that have USB ports for
printers. The Apple Airports also have USB printer ports. The older
ones should be getting cheaper as N comes out.
Posted by Les on June 20, 2008, 3:48 pm
cable internet costs $43 per month. The new service for our community will
be $15 per month. It should be at the same speed.
> superior setup.
Similar ThreadsPosted
adsl internet with netgear wireless router rangemax router problems February 11, 2007, 6:56 am
XP Home PC hardwired to router and XP Pro Laptop wireless through 2Wire router... September 16, 2005, 10:46 am
Adding a wireless router to an existing network with Cisco router March 31, 2006, 3:13 pm
Re: Cable modem --> wireless router --> wired router --> computer. September 9, 2007, 10:42 pm
routing problem between ADSL router and wireless router February 27, 2006, 9:58 am
Internet connection from Wired router to Wireless router ? September 28, 2006, 11:46 am
[How to] wireless network: modem/router + wifi router January 9, 2007, 9:23 am
wireless router connecting to ethernet router July 14, 2005, 4:24 pm
Connecting wireless router to main router October 15, 2005, 2:37 pm
Vonage router-wireless router question November 14, 2005, 7:24 pm
Wireless router + wired router = insanity July 31, 2006, 5:28 am
Can a wireless router with ADSL modem use as a wireless router? April 10, 2006, 7:41 am
connect a wireless router to a wireless router wirelessly April 3, 2007, 3:46 pm
Connect a wireless router to another wireless router?? URGENT November 7, 2007, 11:29 pm
wireless router to wireless router - can any consumer routers do this? April 25, 2008, 11:12 am
