Wireless Networking DD-WRT VPN
Subject Author Date
DD-WRT VPN Adair Winter 07-02-08
---> Re: DD-WRT VPN Bill Kearney07-02-08
| `--> Re: DD-WRT VPN Adair Winter07-02-08
|--> Re: DD-WRT VPN Jeff Liebermann07-02-08
Posted by Adair Winter on July 2, 2008, 10:33 am
Curious if anyone knows how well or if at all DD-WRT works in a multipoint
VPN enviroment.
What we want to do is interconnect 3 maybe 4 sites together.
After doing some reading it appears that you have a host side and a client
side which I assume the host can support multipul clients. but is that the
only configuration or can I take and connect a node that's already a client
and also use it as a host and allow another client to connect to it?
Reason for asking in the setup we want all sites to be able to communicate
with each other but don't want traffic to have to pass thru the host to get
there. So some sort of a star configuration would be needed.
I realize this is a wireless group but DD-WRT is heavely used here so just
looking for comments.
Thanks,
Adair
Posted by Bill Kearney on July 2, 2008, 11:07 am
You do realize the low-power devices that can run DD-WRT are probably not
ideal for this sort of thing, right?
Doing multi-site interconnects is not trivial. Setting up the routing
tables to avoid congestion can be pretty complex. Trying to daisy-chain
mulitple sites really complicates matters. And besides the routing issues,
you also have to contend with inter-site server and workstation traffic. If
you just "set it up" in a trivial manner you'll have enormous amounts of
bandwidth getting wasted on site-to-site overhead traffic.
Try asking on the dd-wrt forums. Then budget for proper Cisco gear.
-Bill Kearney
> VPN enviroment.
> client side which I assume the host can support multipul clients. but is
> that the only configuration or can I take and connect a node that's
> already a client and also use it as a host and allow another client to
> connect to it?
> get there. So some sort of a star configuration would be needed.
Posted by Adair Winter on July 2, 2008, 11:28 am
> issues, you also have to contend with inter-site server and workstation
> traffic. If you just "set it up" in a trivial manner you'll have enormous
> amounts of bandwidth getting wasted on site-to-site overhead traffic.
> -Bill Kearney
I agree, and this is not for an office/work enviroment. It is going to be
used to connect 2 maybe 3 NXU radio liking devices from several places
across the country back to my area. So in reality I only need to be able to
have the server and 1 or 2 clients. Each tunnle will be bridging to another
home network and the only traffic across them will be a single 24Kbps VoIP
stream and managment traffic.
The ability to configure as a star was brought up by someone else but in
reality i do not think it's necessary. If these devices supported host names
and not just static ips they would be placed out on the open internet.
Adair
Posted by Jeff Liebermann on July 2, 2008, 12:25 pm
wrote:
>More on IPerf and JPerf:
><http://www.openmaniak.com/iperf.php> (near bottom)
><http://code.google.com/p/xjperf/>
><http://xjperf.googlecode.com/files/jperf2.0.0.zip>
One more URL:
<http://www.openmaniak.com/iperf.php> (Tutorial with examples)
Jeff Liebermann jeffl@cruzio.com
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Posted by Jeff Liebermann on July 2, 2008, 9:15 pm
wrote:
>Thanks for the input Jeff as always your helpful.
Thanks.
>As I stated befor be do
>not need a ton of bandwidth but I also know what it like to run anything on
>hardware that is being pushed beyond it's limits.
I forgot that I have a nailed up VPN running between my house and
office with a WRT54G v3 at one end, and a Buffalo WHR-HP-G54 at the
other. I'll run some bechmarks this weekend and see what happens.
>Anyone want to suggest some other solutions for the VPN that wont require
>stupid expensive hardware and ideally can be placed behind the firewalls
>that are in place.. I.E the VPN hardware just creates the tunnel thru the
>WAN router. Id be more interested in a solution that would let us reuse
>exsisting hardware we might already have
Sure. I've used various Sonicwall products to build multiple
connection VPN's. The messiest was 5 locations in 3 states via DSL
and T1 lines. Speed was limited by the outgoing bandwidth of the DSL
lines, not the processor. Unfortunately, it was an older Sonicwall
10, which is no longer manufactured.
I've also used Netscreen hardware, which is now part of Jupiter
Networks. One huge advantage was that Netscreen simultaneously
supports PPTP (for Windoze client dial-in) and IPSec (for router to
router). Netscreen is basically Linux on the inside.
I've also use FreeSWAN on Red Hat and OpenVPN SSL on Ubuntu between 3
sites. This was a bit of major project and learning curve for me. I
finally had to yell for help and hired a local student to make it all
work. It's been up for about 2 years and I'm still recovering from
some of the odd tweaks the student threw into the servers. The Linux
boxes currently run on 2GBytes Compact Flash drives (no hard disk). A
big advantage is the ability to easily deal with static routes and
complex firewall issues, as there's an Asterisk server running on one
of the servers. The only problem is that the business owner insists
that I document everything in case I should suddenly die or go on
vacation.
One of my friends has a local store and the owners house connected
with a pair of Linksys BEFVP41 v2 routers running IPSec. They work,
but are what I describe as "tempermental". They hang, crash, die, or
reboot, for no obvious reason. I've recommended replacement, but the
owner claims he doesn't use the VPN very much and is willing to
tolerate the instabilities. Not recommended.
I've tried various Netgear routers that terminate VPN's. I never
could get them to work the way I thought they should work, so I gave
up. I suspect it might have been possible if I had bothered to read
the instructions.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831-336-2558 jeffl@comix.santa-cruz.ca.us
# http://802.11junk.com jeffl@cruzio.com
# http://www.LearnByDestroying.com AE6KS
Similar ThreadsPosted
WRTG2.0 and DDWRT firmware March 6, 2006, 12:55 pm
Actiontec GT701 and WRT54G (Running DDWRT Micro) October 30, 2006, 12:09 am
