Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Sharon on May 30, 2008, 1:25 pm
Please log in for more thread options Can you confirm a Windows Wireless Zero Configuration bug I'm seeing? Once confirmed, how do we report this to the Microsoft WZC team? Bug: Windows Wireless Zero Configuration (WZC), using WPA2-PSK AES, grays out the "Network Key" field when the SSID is not broadcast. It is impossible to enter the network key without resorting to broadcasting your SSID. Details: You can't set up your WinXP Home (WPA2-PSK AES) network without broadcasting your SSID (at least temporarily). This is, IMHO, a bug. To Reproduce ..... 1. Start Fresh: - Remove your current WinXP Home network connection by selecting your network SSID and pressing the "Remove" button in the "Wireless Network Connection Properties" form, press OK, and reboot your WinXP Home computer. 2. Set your router to not broadcast your SSID: - On your router (mine is a Linksys WRT54G), if you have not done so already, please turn off broadcasting of your SSID & set your "Security mode = WPA2 Personal" (aka "Network Authentication = WPA2-PSK"), set your "WPA Algorithm = AES" (aka "Data encryption = AES"), and enter your desired "WPA Shared Key" (aka "Network key"). 3. Try to add your WPA2-PSK/AEs network WITHOUT broacasting your SSID! - On WinXP Home, bring up the "Wireless Network Connection Properties" form and click the "Wireless Networks" tab. Since you removed your network, you should not see it in the "Preferred networks" box. - Press the "Add" button. In the "Accociation" tab of the "Wireless network properties" form that pops up, enter your SSID name in the "Network name (SSID)" field, check the box to "Connect even if this network is not broadcasting", and in the "Wireless network key" section, select "Network Authentication = WPA2-PSK" and "Data encryption = AES". - Notice you need to enter a "Network key" and you must "Confirm network key" but inexplicably, both are grayed out. You can not enter the network key with the SSID not broadcasting! This is the bug. 4. To set your network up, tell your router to broadcast the SSID. 5. Repeat step 3 above. Now you can enter your network key. 6. Go back to your router and disable the broadcast of your SSID. | |||||||||||||
Posted by LR on May 30, 2008, 1:50 pm
Please log in for more thread options Did you uncheck the "The key is provided for me automatically" box before switching from "Open" Network Authentication to "WPA2-PSK"? You can not enter the network > key with the SSID not broadcasting! This is the bug.
> > 4. To set your network up, tell your router to broadcast the SSID. > > 5. Repeat step 3 above. Now you can enter your network key. > > 6. Go back to your router and disable the broadcast of your SSID. | |||||||||||||
Posted by Sharon on May 30, 2008, 2:08 pm
Please log in for more thread options On Fri, 30 May 2008 18:50:59 +0100, LR wrote:
> before switching from "Open" Network Authentication to "WPA2-PSK"? Oh my! No. I did not touch that and it was checked by default. Silly me. I apologize. I will try it again from scratch and report back! | |||||||||||||
| Similar Threads | Posted |
| Can someone else reproduce this WinXP Home WPA2-PSK AES WZC bug? | May 30, 2008, 1:25 pm |
| Challenges with AR5005g card under WinXP home | September 19, 2007, 1:56 pm |
| WEP key in WinXP | December 6, 2006, 1:29 am |
| MA521 WinXP | May 5, 2005, 8:35 pm |
| WinXP and channel | June 10, 2005, 4:49 am |
| WinXP Wireless | February 21, 2006, 8:03 pm |
| 1394 connection in winXP | June 12, 2005, 1:19 pm |
| Needed: WPA Patch for WinXP | April 8, 2007, 1:45 am |
| will winxp give me a choice | July 20, 2008, 12:28 am |
| WinXP wireless problem... | November 24, 2008, 4:34 pm |
| WinXP secure wireless network - how? | December 27, 2004, 3:16 am |
| Old problems never die: WinXP WLAN disconnections | January 5, 2005, 3:35 pm |
| WinXP SP2 "pick strongest signal"? | March 26, 2005, 8:55 am |
| WRT54G pings under WinXP, not Linux. Why? | February 28, 2006, 1:37 pm |
| Which of these netstat connections should be banned on WinXP? | March 23, 2006, 2:58 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> SSID.
> Details:
> To Reproduce .....
> 1. Start Fresh:
