Wireless Networking Boosting outgoing signal
Subject Author Date
Boosting outgoing signal jberry 06-19-05
Posted by on June 19, 2005, 6:47 pm
A topic with a similar name appeared a few months ago; I have a similar
question.
I have a laptop with a Belkin PCMCIA wireless card. Where I am
staying, I can pick up a local wireless hotspot (it is not an unsecured
signal of a neighbour) using 802.11b. Download connectivity is good,
with 40-80 kBps file transfer. Upload is a whole other world, with
communication going at maybe 175 Bytes per second (note, no k). This
kind of makes sense, because the horking big transmitter can be picked
up by my little Belkin even indoors, but it is surprising that their
tower can pick up the transmission from my card at all.
So I was thinking: what if I used something else at hand? I have an
SMC Barricade g SMC2804WBRP-G router, 802.11g. I could mount it in a
window facing this tower to get the best possible signal. I can connect
this to my computer using an ethernet cable, but it doesn't want to
connect to the outside world by wireless. I guess I'm trying to put a
square peg in a round hole. Or maybe trying to eat a sandwich without
having my teeth touch bread first.
Two questions:
1. Is it possible to make a router work like a wireless card? It has a
whole alphabet soup of possible configurations, such as PPPoE, but I
don't know where to start.
2. What is the name of the hardware I should be looking for to do this
task, and are there any recommendations.
Jonathan Berry
Posted by Floyd L. Davidson on June 19, 2005, 6:43 pm
That might be the case, but I doubt it. However you can check it find
out!
Take your laptop for a stroll. Plonk it down somewhere in the
near vicinity of this tower (anywhere that you are positive will
give you a really good signal), and try it there. If you then
get a good uplink bitrate, all of this is worth thinking about.
If you get the same old slow pokey rate, it ain't gonna do us
any good to worry about how you connect!
I'm not familiar with that particular router.
>Two questions:
Some will do it, some won't. What you want to look for is
something like "Client Mode", as opposed to "Access Point Mode".
To work as a router with wifi access it has to be an Access
Point, and might very well have no way to switch it to act as a
Client.
The various WRT54G(S) models from Linksys will do it *if* you
upload one of the various third party firmware packages.
It is also possible that some brand of repeater will work too.
But since they tend to work only with AP of the same brand,
without knowing what model the AP is, it's a real crap shoot to
try repeaters.
Floyd L. Davidson <http://web.newsguy.com/floyd_davidson>
Ukpeagvik (Barrow, Alaska) floyd@barrow.com
Posted by on June 19, 2005, 10:48 pm
Thanks for your help!
The pdf manual says I can disable the "wireless module function", but
no mention of "client mode". Lots of hits for "client" but nothing
resembling "client mode".
Looks like I should have bought the highly user-configurable Linksys
instead of the mail-in rebate coupon SMC.
Jonathan Berry
Similar ThreadsPosted
Boosting outgoing signal June 19, 2005, 6:47 pm
signal boosting to 500 ft February 21, 2007, 9:05 am
Boosting Signal December 29, 2007, 12:49 pm
Boosting incoming signal March 19, 2005, 6:34 am
Boosting WiFi Signal September 8, 2006, 9:05 am
signal boosting for skype February 18, 2007, 1:26 pm
Boosting wireless signal March 20, 2007, 3:53 pm
Boosting the Signal on a WRT54G November 12, 2007, 2:23 am
Signal boosting Belkin July 1, 2008, 4:48 pm
Signal Boosting with a Hawking HSB1 December 5, 2004, 10:08 pm
range expansion/signal boosting December 22, 2004, 3:59 pm
Help with Boosting wireless router signal October 7, 2005, 9:25 pm
Wireless Signal Boosting from One House to Another June 24, 2008, 11:06 pm
"Boosting" the ability to receive a wireless signal?? August 16, 2006, 12:07 am
Boosting signal for your laptop's internal wireless card thread May 19, 2008, 7:25 pm
