Wireless Networking Boosting WiFi Signal
Subject Author Date
Boosting WiFi Signal Vibhu 09-08-06
Posted by Vibhu on September 8, 2006, 9:05 am
Hey!
I have WiFi Signals (Strength 35%) coming right till my window.
The moment windows is closed, the signals are gone.
I would like to know how can I boost my wifi signals..
Thanks in advance
Vibhu
Posted by Jeff Liebermann on September 8, 2006, 11:40 am
>Hey!
Huh?
I'll assume that the window has some type of aluminized mylar coating,
which is blocking the signal. If you can remove this coating, the
signal should go through the window. If the window does NOT have a
aluminized mylar coating, then the location of your test radio is not
ideal for passing the signal through the window. If possible, try to
relocated it. If not possible, attach an external antenna to the test
radio, drill a hole in the wall somewhere, pass the coax cable through
the wall, and attach an external antenna.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Posted by Vibhu on September 12, 2006, 3:14 pm
Thanks Jeff!
Their is one thing more I would like to know, if you are aware of any
device, say USB, which can amplify the signal.
Is that a possibility.
Regards
Jeff Liebermann wrote:
> >Hey!
> Huh?
Posted by Jeff Liebermann on September 13, 2006, 1:22 am
No. Repeaters and "range extenders" as usually stand alone devices
that run on AC power (through a wall wart). I don't know of any that
will run off of USB. However, if the power consumption is fairly low,
and it can run on the 5VDC 1A that a USB jack can supply, then you
might be able to kludge something.
Is that a questions? If it is, then the answer is no. I'm not a big
fan of "range extenders" whether powered by AC, solar, or USB.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831-336-2558 jeffl@comix.santa-cruz.ca.us
# http://802.11junk.com jeffl@cruzio.com
# http://www.LearnByDestroying.com AE6KS
Posted by Vibhu on September 13, 2006, 2:31 am
Okey, I plan to invest in a range booster (I'll go for AC one).
Any suggestions which one's should I go in for.
I tried searching it on the internet, but their are to many of them to
choose from.
Thanks
Similar ThreadsPosted
Boosting WiFi Signal September 8, 2006, 9:05 am
signal boosting to 500 ft February 21, 2007, 9:05 am
Boosting Signal December 29, 2007, 12:49 pm
Boosting incoming signal March 19, 2005, 6:34 am
Boosting outgoing signal June 19, 2005, 6:47 pm
signal boosting for skype February 18, 2007, 1:26 pm
Boosting wireless signal March 20, 2007, 3:53 pm
Boosting the Signal on a WRT54G November 12, 2007, 2:23 am
Signal boosting Belkin July 1, 2008, 4:48 pm
Signal Boosting with a Hawking HSB1 December 5, 2004, 10:08 pm
range expansion/signal boosting December 22, 2004, 3:59 pm
Help with Boosting wireless router signal October 7, 2005, 9:25 pm
Wireless Signal Boosting from One House to Another June 24, 2008, 11:06 pm
"Boosting" the ability to receive a wireless signal?? August 16, 2006, 12:07 am
Boosting signal for your laptop's internal wireless card thread May 19, 2008, 7:25 pm
