Wireless Networking Belkin Router & file transfer help wanted please
Subject Author Date
Belkin Router & file transfer help wanted please Kenny 07-30-07
Posted by Kenny on July 30, 2007, 7:05 pm
Hi, i have just installed a Belkin 4 port wireless router.
My DeskTop PC is wireless to it and so is my Notebook PC.
Am I able to just send a file, example (music file) from notebook to DeskTop
PC? If so How do I go about it?
ken
Posted by Alan Spicer on July 31, 2007, 12:05 am
* Make sure they are both on the same workgroup. Make sure Windows firewalls
on both are allowing File and Printer Sharing. Right click a folder on the
desktop and pick Sharing and Security. You should be able to enable sharing
of that folder right there. The go in Network Places on the laptop and you
should be able to put a file there. Don't forget to check "allow network
users to change my files" or else you will get a permission denied on
copying (and hence creating a new file in that folder).
This assumes you don't have any after-market firewall software on either
computer. And that you're doing the normal automatic IP Addressing from your
router, so that both computers are on the same IP Address range. You can
check that in a Start > Run > cmd > [OK]. Command prompt with the command
"ipconfig". Or just double click the wireless icon down by the clock on the
bottom task bar and hit the Support tab and check the IP Settings.
Alan Spicer
DBA Alan Spicer Telcom / Alan Spicer Marine Telecom
Computer Services, Wired/Wireless Networking,
Cell/Sat/Landline Communications, General Consulting...
Marine, Business, Small Office and Home Office (SOHO)
* http://telecom.dyndns.biz/ (Main Site)
* http://www.marinetelecom.net/ (.net mirror site)
* http://alanspicermarinetelecom.com/ (.com mirror site)
* http://www.wifiyacht.net/ (Yacht WiFi Main Site)
* http://www.mymarinewifi.com/ (Marine WiFi .com mirror site)
> DeskTop PC? If so How do I go about it?
> ken
Posted by Jeff Liebermann on July 31, 2007, 12:49 am
Model number? Oh never mind...
Wireless is exactly like wired. Lookup how to setup Windoze sharing.
<http://support.microsoft.com/kb/304040>
Yech, way to complicated.
More better:
<http://www.practicallynetworked.com/sharing/xp/filesharing.htm>
<http://www.howtonetworking.com/workgroupsetup.htm>
Jeff Liebermann jeffl@cruzio.com
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Posted by Kenny on July 31, 2007, 6:56 pm
Thank you for the replies.
I have both computers working wireless to the Router.
But still can't get the transfer of a music file to go from laptop temp
folder to DeskTop C:\Temp folder
Can possibly i use limewire would that be interesting
Similar ThreadsPosted
Belkin Router & file transfer help wanted please July 30, 2007, 7:05 pm
Advice wanted on Belkin modem/router July 1, 2005, 12:47 pm
File Transfer on Wireless June 4, 2006, 7:13 pm
Network File Transfer Software? November 25, 2004, 3:45 pm
Program to transfer file over Wifi December 24, 2005, 9:16 pm
Belkin MIMO Firm-ware wanted please November 25, 2006, 4:14 am
Wireless Drops During File Transfer (Netgear mr814 version 1) July 27, 2006, 7:54 pm
wanted cable router CHEAP September 12, 2007, 4:28 am
Belkin Pre-N Save file takes long time. February 1, 2005, 6:53 am
Low local transfer on WRT54GL router November 13, 2008, 2:25 pm
Any idea for a router transfer speed benchmark ? September 7, 2005, 3:03 am
PC to Router doesnt allow any data transfer at all. Advice needed please... September 19, 2005, 10:07 am
Netgear WGR614 wireless router and XP - connection exists but no data transfer February 10, 2005, 11:20 am
A Belkin Pre-N router with Belkin Pre-N PCMCIA card : Question January 8, 2005, 7:29 am
belkin wireless router, Belkin F5D7230-4 October 27, 2004, 12:19 pm
